Please help! 2016 Sportsman 850 - Polaris ATV Forum
post #1 of 5 (permalink) Old 08-13-2019, 04:56 PM Thread Starter
Sportsman_850's Avatar
So I was out mudding on the trails this weekend and drowned it a few times but luckily hit the killswitch before it went under. But it had no power. Started up fine and idled fine but no real power. Just thought my plugs got wet, water in gas, or something. Got it home took the plugs not to bad, the air filter was a little soggy but it still started up with no power. Checked the dipstick to see if there was water in the oil and it looked good. Went to start it again and the dipstick blew out and was sheared off about half way. Sound familiar to anyone? Im kinda at a loss and afraid to try and start it again if the is something failing internally.
Sportsman_850 is offline
post #2 of 5 (permalink) Old 08-13-2019, 06:03 PM
FPD218's Avatar
Sounds like you may have water in your belt housing, there is a RED plug in the bottom, pull it and see if water comes out.
The Oil Dipstick, you didn't put it in straight and when the crankshaft rotated you broke it off, many on this sight have done that....... some fish out the broken plastic some don't.....
JUNE 2017 & SEPTEMBER 2018 POLARIS FORUM ATV OF THE MONTH WINNER
2019 Sportsman 850 SP Premium
Removed all Warning Decals
3500# Polaris Winch W/Synthetic Rope
Winch Stopper Cable Line Saver
ATV-GURU.COM Front and Rear Bumpers
2" Receiver in Front Bumper
Kenda K587 HTR Bear Claws 26X9X14 & 26X11X14
Ultimate Series Windshield Fairing, Mid & Low Height Windshield
New Style Polaris Lock & Ride Rear Storage Box
Garmin GPS176C, Ram Mount
Polaris Rear View Mirrors
4" Front Rack Extender
Center Brake/Tail Light LED
Rear LED work lights/strobes
Built on March 27 2019
Purchased New April 13 2019 0.1 Hr .2 Mi
Power Sports Abrams, Wi
SOLD
2006 Sportsman 800 EFI Twin
Purchased new to me on Aug 08 2016 97Hr's 811Mi
Sold Apr 07 2019 231 Hr 3126 Mi
https://www.youtube.com/watch?time_c...&v=k6Nlb_qRoeg
"I am the majority!"
*WEAR A HELMET, I'M LIVING PROOF THEY WORK!
FPD218 is offline
post #3 of 5 (permalink) Old 08-14-2019, 01:51 AM Thread Starter
I already ordered a flexible grabber tool and a lighted endoscope to try and finish out the dipstick piece. But I think maybe I mis spoke. The engine almost falls down on itself when I go to rev it. It doesn't rev up and not move the bike. It just doesn't rev at all. It wants to but stops. To add to it when I was out on the trail I was getting a LO 7.8 message then eventually my display and speedo stopped all together.
post #4 of 5 (permalink) Old 08-14-2019, 05:37 AM
bp405's Avatar
Remove every electrical connector, dry it with shop air, clean it with electrical connector cleaner, and die-electric grease it.
I would also test dc voltage at the battery with the machine running preferably at 3.000rpm. Should be 13.5-14.5vdc.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #5 of 5 (permalink) Old 08-14-2019, 08:36 AM
low voltage will affect the ignition and the fuel injection - check that you did not get water in the fuel tank
latebird is online now
