Accessories connections to Battery - Polaris ATV Forum
 1Likes
post #1 of 13 (permalink) Old 08-31-2019, 04:39 PM Thread Starter
callmaker's Avatar
I have 2013 850 HO EPS, Which has a lot of aftermarket accessories that are connected to the battery. Includes winch wiring, LED lights wiring, Etc. This is filling up the bolt length. Last battery installation, several wires didn't get put back on the battery bolts.
What can I do to make this less complicated?
I had considered making a short (3") battery cable, connect all the accessories to one of the lugs and connect the main wiring and other lug to the battery. This way all the accessories stay together. Would this work?
Sent from my Moto Z (2) using Tapatalk
callmaker is online now
post #2 of 13 (permalink) Old 08-31-2019, 04:56 PM
Jason537's Avatar
Should work,.. but I just cleaned up the wiring and put a longer bolt in mine.
Hers 2014 570 sportsman,
2" AtvE lift
His 2013 850xp LE,
28" Zillas
1.5" lift
LTE slip-on,
Welded timing gear
Jason537 is offline
post #3 of 13 (permalink) Old 08-31-2019, 04:58 PM
bp405's Avatar
I bought some terminal blocks from JEGS. Basically brought a cable from each battery terminal (+/-) to the block and then jumped off the block.
ID:	119911   Click image for larger version
callmaker likes this.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #4 of 13 (permalink) Old 09-16-2019, 10:04 AM Thread Starter
callmaker's Avatar
Bought one of the Jegg's blocks, now to find a place to position it out of the way under the removable front rack.
There were instructions, so I'm assuming, run a red wire from the battery to a post on the Jegg's, and a black wire from the battery to the other post on the Jegg's??
post #5 of 13 (permalink) Old 09-16-2019, 12:52 PM
That is a very insightful assumption - I think you are onto something there
latebird is online now
post #6 of 13 (permalink) Old 09-16-2019, 01:28 PM
bp405's Avatar
Yup that's all there is to it. You can double up on either post. For the bigger wires I used the bigger post and for the smaller wires I used the smaller post from the JEGS terminal block.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #7 of 13 (permalink) Old 09-16-2019, 01:45 PM Thread Starter
callmaker's Avatar
Yea, I see the post size difference now.
So, the two posts are not connected?
So, I can get by with just one of these "Terminal Blocks"?
post #8 of 13 (permalink) Old 09-16-2019, 01:55 PM
bp405's Avatar
No they are most definitely connected. Under the plastic the terminals are all one piece. You need both!!!
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #9 of 13 (permalink) Old 09-16-2019, 03:50 PM
Gmartino100's Avatar
Actually this specific terminal block is not connected. There is an optional bus bar that you can install that will connect the two terminal points, otherwise they are separate.
For the OP, you can use one for positive and one for negative, or install the bus bar and use it for positive only and ground your other wires separately.
“I'm not lost for I know where I am. But however, where I am may be lost.” – Pooh
Gmartino100 is offline
post #10 of 13 (permalink) Old 09-16-2019, 04:17 PM
bp405's Avatar
I stand corrected, THEY ARE NOT MOST DEFINITELY CONNECTED. Lol!!!! Its been about three years since I installed them. Personally I wouldn't use just one. The Pos. and Neg. are to close for comfort. To easy for a slip and boom!!!!
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
