2014 500 efi bobcat 3400xl - Polaris ATV Forum
post #1 of 38 (permalink) Old 09-02-2019, 07:27 AM Thread Starter
alexhaleyschneider's Avatar
hey guys was wondering if anybody knows if i can swap my primary clutch on my 2014 bobcat/polaris 500 efi with a different model or type?
alexhaleyschneider is offline
post #2 of 38 (permalink) Old 09-02-2019, 09:45 AM
Yep, my understanding is that they are just a Polaris Ranger in Bobcat skin.
polman500 is offline
post #3 of 38 (permalink) Old 09-02-2019, 01:29 PM Thread Starter
ok--any idea what model of clutch would fit on this 500 efi motor?
post #4 of 38 (permalink) Old 09-02-2019, 03:13 PM
Yeah, many Polaris clutches would fit but the difference is in spring, weights, belt and slight design changes over the years. Polaris part number 1322965 would probably be the closest to an exact match for the OEM clutch you have.
Here's a list of the Polaris machines that particular clutch comes as OEM on:
2013 RGR RANGER 500 MIDSIZE DRIVE TRAIN, PRIMARY CLUTCH - R13RH50AG/AH/AM/AR (49RGRCLUTCHDRV11500EFI)
2013 RGR RANGER 500 CREW MIDSIZE DRIVE TRAIN, PRIMARY CLUTCH - R13WH50AG/AH/AR/AX (49RGRCLUTCHDRV11500EFI)
2012 RGR RANGER 500 4X4 DRIVE TRAIN, PRIMARY CLUTCH - R12RH50AG/AH/AM/AR/AZ (49RGRCLUTCHDRV11500EFI)
2012 RGR RANGER 500 4X4 CREW DRIVE TRAIN, PRIMARY CLUTCH - R12WH50AG/AH/AK/AR (49RGRCLUTCHDRV11500EFI)
2011 RGR RANGER 4X4 500 EFI DRIVE TRAIN, PRIMARY CLUTCH - R11RH50AG/AH/AR (49RGRCLUTCHDRV11500EFI)
2011 RGR RANGER 4X4 500 CREW DRIVE TRAIN, PRIMARY CLUTCH - R11WH50AG/AH/AR (49RGRCLUTCHDRV11500EFI)
post #5 of 38 (permalink) Old 09-02-2019, 03:31 PM
The original clutch can be rebuilt for around $200 if you have the right tools and parts.
I'd be interested in the old one if you're gonna replace it.
post #6 of 38 (permalink) Old 09-11-2019, 07:03 AM Thread Starter
if u wanna send me an empty box with return ship tag you can have it---another question occasionally my machine just quits for no reason and wont restart unless u wait 5 minutes--its weird it will do 3 times in a 30 minute period then it might not do it for 3 days--any ideas?
post #7 of 38 (permalink) Old 09-11-2019, 08:31 AM
Ok, I'll see what return shipping it needs and send you a PM to get the address.
Does the fuel pump prime up when you turn the key on during the no start condition?
I'd first check battery cables and connections but from what you describe it sorta sounds like a faulty efi relay. Look in the lid of the fuse/relay block and it should show which runs the efi. If it has relays that look like those in the picture in the ebay link below, they are interchangeable and run things like the fan, power steering and efi so you can swap them out and see if the problem follows the relay to determine if that's what it is.
https://www.ebay.com/itm/2x-Polaris-...AAAOSw~89akKTb
post #8 of 38 (permalink) Old 09-11-2019, 09:53 AM Thread Starter
i pulled all 4 relays and the efi prongs were oxidized and the other 3 relays looked perfect--so i swapped the fan and efi relay--will see what happens--thanx
post #9 of 38 (permalink) Old 09-11-2019, 04:48 PM Thread Starter
i tried the relay and it still killed--i ran it today for about 15 minutes then it killed 4 times in a mile and each time i had to wait 5 minutes before it would fire--then after the fourth time i ran it for 6 miles with no issues till it did it again.---every time like clockwork i have to wait 5 minutes before it will fire--if i try it sooner it just cranks and doesnt fire--it has the feel of something getting hot and shutting it down but i dont know what--i have allready wire my fan to run all the time--
post #10 of 38 (permalink) Old 09-11-2019, 05:35 PM
You still didn't say if you can hear the fuel pump run when you turn the key during the no start condition??
Just turn the key on and don't try to start.
