2015 sportsman 570 regulator issues - Polaris ATV Forum
 1Likes
  • 1 Post By EvoBoy
post #1 of 10 (permalink) Old 09-06-2019, 08:37 PM Thread Starter
Quadguy36's Avatar
Have a 2015 570 has 60 hours on it roughly now. Went to go for a ride today and check engine light came on and power steering light, pulled codes and had a 168-3 something about system over voltage. Checked the voltage gauge on cluster and when reved up i can see as high as 16-18 volts but 14-14.4 at idle. Curious if you guys ever see this issue with the regulators in these things.
Quadguy36 is offline
post #2 of 10 (permalink) Old 09-06-2019, 10:52 PM
Yep, the 570 is well known for junk VR's
I've found that the display voltage is sometimes very inaccurate too.
Check your charging system with a meter to know for sure what's going on. If it is in fact over charging replace the VR
polman500 is offline
post #3 of 10 (permalink) Old 09-07-2019, 02:25 AM
bp405's Avatar
Definitely sounds of the symptoms of a bad VR. I'm going to try these guys out if and when I need to: https://squareup.com/store/cycleworx...QogppzbGct7c4s.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
2020 Outlander® 1000R XXC
bp405 is online now
post #4 of 10 (permalink) Old 09-07-2019, 06:28 AM Thread Starter
Quadguy36's Avatar
Im gonna give it a better check over this evening, with my multi meter and make sure i have no rubbed through wires or anything. And that regulator looks nice, is pricey tho... but i suppose if it “never fails” it would be worth it. Do guy ever have issues with the stators on these bikes? Im sure my issue is a regulator but just curious
post #5 of 10 (permalink) Old 09-07-2019, 10:17 AM
bp405's Avatar
Stators seem to be fine for the most part.
Over voltage is typically the VR.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #6 of 10 (permalink) Old 09-07-2019, 12:41 PM
rainmanx's Avatar
Polaris has updated the regulators for 2019. Might not be worth the extra cost of the aftermarket one.
rainmanx is offline
post #7 of 10 (permalink) Old 09-08-2019, 03:00 AM
EvoBoy's Avatar
My 2014 had same issue but only when the VR got hot and then would stop charging. Fine since dealer replaced the VR.
sportsmandan likes this.
EvoBoy is offline
post #8 of 10 (permalink) Old 09-09-2019, 05:37 PM Thread Starter
Quadguy36's Avatar
Well i checked out the wiring today, all seems fine no chaffing or poor connections. Decided to go with a Mofset VR from RMstator was cheap at 180$ shipped v.s the 289$ + tax polaris wanted. Should be here by the end of the week i hope!
post #9 of 10 (permalink) Old 09-12-2019, 07:31 PM Thread Starter
Quadguy36's Avatar
Well got the new regulator a day early decided to try and fault my original one again and couldn't get it to do it. Installed the “quality” rmStator regulator... even came in an unmarked box labeled “made in china” right on is and to no surprise overcharges at 15.2 volts. Confirmed it with a multimeter also. So somewhat stumped as to my actual issue unless its really just a Chinese made pile of garbage regulator. Emailed RMstator see what comes of it i suppose. Anyone else ever purchased their parts?
post #10 of 10 (permalink) Old 09-13-2019, 02:13 AM
Sprotsman's Avatar
Never again. I’ll leave it at that.
Sprotsman is online now
