2016 570 SP Battery Tender Connections - Polaris ATV Forum
 2Likes
post #1 of 23 (permalink) Old 09-12-2019, 03:52 PM Thread Starter
jdinaz's Avatar
I'm a new owner of a 2016 570 SP and have a question....it took me a minute to find the battery way down there on the frame, I haven't messed with it yet, but I'd like to install the quick connect for a battery tender, question is, is there an easier connection point higher up somewhere to connect to? Like I said, I haven't looked at it too much yet, so I apologize if it's obvious....thank you !
jdinaz is offline
post #2 of 23 (permalink) Old 09-12-2019, 04:01 PM
rainmanx's Avatar
If it's like the 2019...Pull the center plate in the front box..Under it you will find a terminal block. Much easier to install a permanent connector. Polaris sells an accessory that is $50 to place terminals in side the box.
rainmanx is offline
post #3 of 23 (permalink) Old 09-12-2019, 04:12 PM Thread Starter
jdinaz's Avatar
Thank you for the quick reply Rainmanx, I'll have to go do some looking at it, I assume you are talking about the front storage box?
John
2016 570 SP
jdinaz is offline
post #4 of 23 (permalink) Old 09-12-2019, 05:03 PM
Sprotsman's Avatar
These work great. Has permanent fused terminal connector that just pokes out of front grill.
https://rover.ebay.com/rover/0/0/0?m...2F331960260648
boulderskies likes this.
Sprotsman is online now
post #5 of 23 (permalink) Old 09-12-2019, 08:48 PM Thread Starter
jdinaz's Avatar
That's exactly what I use Sprotsman, I'm just looking for the best place to connect the fused line. Thanks !
John
2016 570 SP
jdinaz is offline
post #6 of 23 (permalink) Old 09-12-2019, 09:38 PM
rainmanx's Avatar
Yes..Front storage box.
rainmanx is offline
post #7 of 23 (permalink) Old 09-13-2019, 05:24 AM
hogn99's Avatar
If you hook this up to terminal block send pics of how you did it. I put quick connect straight to battery and ran the plug up the frame next to reservoir and zip tied just under storage box. When I need to plug in I can reach under front left fender.
2016 Sportsman 570 EPS - Sage Green
-Polaris front rack extender
2016 Sportsman 570 EPS - Orange Burst
-Polaris 2500# winch w/synthetic cable
-Quadboss Rest and Storage Trunk
2016 Sportsman 570 EPS - Indy Red
hogn99 is offline
post #8 of 23 (permalink) Old 09-13-2019, 08:25 AM
Sprotsman's Avatar
Very simple. Right to the fuse block.
post #9 of 23 (permalink) Old 09-13-2019, 03:55 PM Thread Starter
jdinaz's Avatar
Thanks all, just like Sprotsman said, very simple. Pop the cover, use a meter to make sure you are on the right connections, remove the bolt and install your wires. Run the end connector where ever you want. Be sure and tie wrap the wires to something in order to keep them out of the fan. That simple.....thanks again, saved me a lot of work!
John
2016 570 SP
jdinaz is offline
post #10 of 23 (permalink) Old 09-13-2019, 07:14 PM
Appletonrc's Avatar
I put mine to the fuse box as well. There is the plastic cover the goes over the fuse box, I ran the wire at the seam inside the front storage. It keeps the connector out of the weather/dirt. I open the front storage to charge and then the cable is inside the front storage when I'm driving.
2015 Red Sportsman 570
Polaris 3500 lb winch
Kimpex Outback ATV Trunk with Seat
Polaris hand and thumb warmers
Battery Tender
Appletonrc is offline
