2012 Sportsman 550 EPS ECM pins - Polaris ATV Forum
post #1 of 2 (permalink) Old 09-15-2019, 08:15 PM Thread Starter
windvane's Avatar
Hi, I have a 21012 Polaris Sportsman 550 EPS. Machine has set for a while. Replaced battery and tried to start atv. Wouldn’t start so I started checking connectors, I found that one of the pins on the ECM had turned green and corroded to nothing. Has anyone seen this problem, if so, was there a fix other than replacing ECM and main harness?
windvane is offline
post #2 of 2 (permalink) Old 09-16-2019, 02:06 AM
bp405's Avatar
That happens when there is current going through a connection and moisture is present. That and galvanic corrosion cause these types of issues in electrical components. You can either buy a new ECM or have yours refurbished. In either event it's a good idea to die-electric grease all your electrical connections going forward.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
2020 Outlander® 1000R XXC
bp405 is online now
