error code 0 84 2 PLAUSIBILITY FAULT NEED HELP - Polaris ATV Forum
post #1 of 7 (permalink) Old 09-18-2019, 05:15 PM Thread Starter
ROCKWIND1's Avatar
2011 sportsman error code 0 84 2 PLAUSIBILITY FAULT NEED HELP
2011 polaris sportsman 550 touring
in my manual it says VEHICLE SPEED SIGNAL PLAUSIBILITY FAULT.
ANY IDEAS what this is?
the atv works fine, the check engine light comes on, then the power steering goes out. i thought it was the power steering for a while, but now i think the machine is just shutting it down to deal with tis other problem
i go pretty slow, i am fine with unplugging some sort of speed sensor or the speedo to get this problem to go away during hunting season.
any help or suggestions out there for an easy fix?
thanks
ROCKWIND1 is offline
post #2 of 7 (permalink) Old 09-18-2019, 05:18 PM
bp405's Avatar
What are we working on???
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
2020 Outlander® 1000R XXC
bp405 is online now
post #3 of 7 (permalink) Old 09-18-2019, 05:21 PM Thread Starter
ROCKWIND1's Avatar
oops, 2011 sportsman 550 touring
post #4 of 7 (permalink) Old 09-18-2019, 09:48 PM
Pay close attention to the speedo while moving and see if its jumping around any. It could be a problem with the speed sensor giving a bad signal or having a bad connection.
polman500 is online now
post #5 of 7 (permalink) Old 09-19-2019, 05:13 AM Thread Starter
ROCKWIND1's Avatar
yes, i was hopiong the harness into the speed sensor just needed cleaning but it looks fine so i am going to buy a new speed sensor.
i have noticed that as soon as the engine light/eps light come on, the speedo stops working. i thought it was just shutting down the speedo like it shuts down the power steering.
but i have to go hunting this weekend and will probly have to order online. dang. the local polaris place doesn't seem to stock anything anymore.
everything i have read said that the speed sensor if it doesn't work, your rig won't even run but mine runs fine with the speedo not working and the error lights on.
post #6 of 7 (permalink) Old 09-19-2019, 05:49 AM
bp405's Avatar
With that error code I'd say you are on to it.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #7 of 7 (permalink) Old 09-19-2019, 10:00 AM Thread Starter
ROCKWIND1's Avatar
well,put in a new speed sensor and seemed to fix that problem but now another code is popping up. i was trying really hard to get the old code to pop up but it wouldn't, so i went a little bit faster in low gear than i ever have and this code popped up. was probably going 22 mph on speedo.
102 3
which says manifold absollute pressure sensor high voltage
i wonder if it is just a random thing and as long as i go slow nothing will happen
