Rear tires hitting bodywork on Scrambler 1000XP - Polaris ATV Forum
post #1 of 6 (permalink) Old 09-22-2019, 04:11 AM Thread Starter
Jazzy's Avatar
New '19 Scrambler 1000 XP here, running Maxxis Ceros 26x11R14 in the rear. The tires are hitting the bodywork where the rear body meets the footwell, when landing after a jump or hitting a deep hole.
My buddy has the exact same issue with Maxxiss Bighorns so I assume this is a known issue. How do people typically solve this? I'm considering to heat the bodywork and push it half an inch away.
Have: 2019 Scrambler XP 1000 - 2016 Yamaha YFZ-450r
Had: 2006 Barossa - 2007 Raptor 350 - 2004 Warrior - 1996 Blaster - 2001 Raptor 660 - 1991 Banshee - 1998 Blaster - 2009 Raptor 250 - 2007 Raptor 700SE - SMC Extreme 250 - 2007 Renegade 800 - Yamaha Breeze (2x) - 2011 Raptor 250 - 2008 Outlander 800 Max LTD - 2008 YFZ450 - 2011 Raptor 250 - 1999 Eton AXL90 - 2007 YFZ450SE - 2011 Outlander 800 Max LTD - 2007 Raptor 250 SE - Suzuki LT50 - 2013 Outlander 1000 Max XT-P - 2009 Outlander 650 Max XT - Suzuki LTR450 - 2014 Outlander 1000 Max XT-P - 2009 Raptor 250 - YFZ450 with RMZ250 engine - 2017 Outlander 1000 Max XT-p
Jazzy is offline
post #2 of 6 (permalink) Old 09-22-2019, 09:59 AM
bp405's Avatar
Or trim it, or cut it, or get closer to stock offset rims.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 6 (permalink) Old 09-22-2019, 03:06 PM
catpartsman's Avatar
Forgive me but how would stock offset rims help in this situation? Where the tires are running is under the fender not on the fender flare. Plus those rims look like stock ones to me.
My suggestion would be to stiffen the shocks up a bit. That or trim the fender some.
catpartsman is offline
post #4 of 6 (permalink) Old 09-24-2019, 04:25 AM
TheStatelineATV's Avatar
yeah, looks like a stock offset to me too.BoneStock popo wheel. second to trim it a bit, but wonder how heat job will end
Sent from my SM-N950U using Tapatalk
TheStatelineATV is offline
post #5 of 6 (permalink) Old 09-24-2019, 06:07 AM
bp405's Avatar
Yeah they are stock rims!!! So trim, cut, heat + bend, stiffen the pre-loads.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #6 of 6 (permalink) Old 09-24-2019, 07:57 AM
chronix79's Avatar
I had the same issue until I swapped out to Elkas. If you have the settings on those shocks try stiffening the high speed compression up 2 clicks at a time and try them out. If you get all the way stiff on the high speed compression and it's still hitting you may need a stiffer set of springs. I'm 6'-4" and 280lbs so my springs will look a little beefier, but I attached a pic so you can see how much stiffer my springs look. The shock at the top is the rear one.
2014 Scrambler 1000 xp
  • R2C Filter
  • NGK Spark Plugs
  • Cecco Front & Rear A-Arm braces
  • Cecco Pinion Cover
  • 26" Bear Claw HTRs
  • Garage Products Bushings
  • Flexx Bars
  • 2" Rox Risers
  • Elka Stage 4 Shocks
  • Sirius Pro 10" Light bar
  • American Star 12mm Tie Rods
chronix79 is offline
