opinion on belts - Page 2 - Polaris ATV Forum
post #11 of 15 (permalink) Old 03-13-2014, 07:07 AM
Ezerasurfr's Avatar
Not to completely derail, but I'm curious as to how the belt slipping led to a roll-over. Also, hope everyone's ok (which I'm assuming they are otherwise you prob would have stated it.)
2014 Sportsman 550 EPS
Ezerasurfr is offline
post #12 of 15 (permalink) Old 03-13-2014, 07:31 AM
bp405's Avatar
Happened to one of the can am guys I have ridden with. Basically due to the fact he was running oversized tires with 3,000 miles on the original belt. To compound the situation he haden't done any clutch work to the bike. He was doing a slick moderate hill climb lost momentum due to lack of wheel speed from the belt slipping. Almost made it up then the belt blows apart sending him sliding (brakes locked) backwards into the tree line. Luckily for the tress and the fact that the trail was curved. If it wasn't for those two factors it would have been a lot more damage then a bent rear rack and busted chainsaw mount.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
2020 Outlander® 1000R XXC
bp405 is offline
post #13 of 15 (permalink) Old 03-13-2014, 07:32 AM Thread Starter
ThorsHammer's Avatar
we were headed up a short steep section. My step son was driving. His first time driving that machine (he has a 110cc kid quad) on the trails. I was on the back. heading up the steep spot the belt slipped and we lost momentum and forward progress. as we started to roll backwards my step son gunned it (instead of letting it roll back and taking a second shot) and the belt caught. and over we went. I acted as a roll cage for him as I'd grabbed onto the handle bars the second we lost momentum. and everything was fine. I attempted the hill climb again and couldn't even get enough momentum/speed going to start up the hill because the belt was slipping so bad. Pulled the clutch cover drain plug and let it drain/dry for a bit. once that was done we were back in business, but this time with my step son riding behind a friend of mine and me on my machine alone.
there were two factors that caused us to go over. 1 the slipping belt. and 2 my fat ass on the back. 1/3 of the weight of the machine up high and on the back on a steep section just isn't a good combination. Had he been going up on his own (granted it was short, like I could stand at the bottom and be taller than it) I doubt it would have gone over.
2017 Sportsman 570 Touring EPS
3500 lbs Polaris winch with Synthetic Rope
Front Utility Rack
ODI Rogue Lockon Grips
25" STI Black Diamond ATRs
Pure Polaris hand guards
4" LED on the pod
Quadworks Stage 1 power kit
  • Dynojet kit
2" rear spring spacers
ThorsHammer is offline
post #14 of 15 (permalink) Old 03-15-2014, 02:26 PM
jgcoastie's Avatar
Originally Posted by Amdforever View Post
If you're belt is hourglassing in idle, you have a clutch issue and that problem exists whether its in gear or in park. The primary clutch is always spinning (connected to the crankshaft) and is not affected by what gear you have the bike in at idle. The secondary will always free spin in neutral and park, only in the other gears will it actually try to drive something. So if your belt is moving/rotating at idle in neutral or park, you have a problem.
Wouldn't the primary always have a "grip" on the belt, causing the belt to rotate with the primary all the time? Isn't that why everyone says not to idle in gear? Because the primary is always gripping, therefore spinning the belt?
'12 XP 850HO Touring w/EPS
- Superwinch LT3000
- 27" GBC Grim Reapers
- Polaris Front Bumper
- Xenon Blue Headlights
- Polaris Plow
- 2gal Rotopax
"The makers of the Constitution conferred, as against the government, the right to be let alone the most comprehensive of rights and the right most valued by civilized men."
- Justice Louis D. Brandeis
US Supreme Court
jgcoastie is offline
post #15 of 15 (permalink) Old 03-15-2014, 03:14 PM
Amdforever's Avatar
Nope. The primary should always release the belt at idle. If it were always gripping the belt then that would mean the secondary is always turning, thus making it hard as hell to get into gear
When I installed my QSC clutch kit, due to the weight setup and spring config for mine and my type of riding, the weights were already pushing on the spider at idle, causing the belt to rotate and creating the problems I just mentioned above. I had to add one of their shims just to get it to stop doing that at idle.
Amdforever is offline
belts chadw90 Polaris Sportsman 14 01-21-2014 06:21 AM
going through belts smorrisseau ATV Repair and Maintenance 1 06-19-2012 02:13 PM
belts whitelightning22250 ATV General Discussion 8 02-23-2012 08:15 PM
need opinion???? makeshift13 ATV General Discussion 0 09-08-2011 03:26 PM
Your opinion... eclifford634 ATV Repair and Maintenance 1 08-03-2011 10:37 AM
