2009 sportsman problems - Polaris ATV Forum
post #1 of 10 (permalink) Old 03-15-2014, 05:26 PM Thread Starter
Sportsmanproblems's Avatar
2009 sportsman 400 4x4 problem
Hello everyone. I am new here so bare with me. I just recently bought a 2009 sportsman 400 ho and I am having problems with my front left wheel spinning in awd. The cv joint shaft slipped out of the differential because of the clip so I replaced it. The awd still won't work for the front left wheel. Any suggestions??
Thanks for any help
Sportsmanproblems is offline
post #2 of 10 (permalink) Old 03-15-2014, 05:42 PM
RVS Performance's Avatar
Sure the splines aren't stripped off? Maybe the CV joint is bad on one end or the other?
RVS Performance is offline
post #3 of 10 (permalink) Old 03-15-2014, 05:55 PM Thread Starter
I checked the splines. Both sides are catching and feel the same
post #4 of 10 (permalink) Old 03-16-2014, 09:38 AM
hydewildman's Avatar
Put the atv tires in the air and remove the bad axle. Have someone spin the tires, SLOWLY, and see if the differential is spinning. If not its your axle.
hydewildman is offline
post #5 of 10 (permalink) Old 03-16-2014, 10:10 AM Thread Starter
Do I take the whole axle out of the differential?
post #6 of 10 (permalink) Old 03-16-2014, 10:23 AM
Yes, remove the axle from the diff and watch to see if the diff splines are spinning while the bike is running. If they do then you will know that the problem is with the axle.
post #7 of 10 (permalink) Old 03-16-2014, 10:29 AM Thread Starter
How do I get the axle out without breaking the clip?
post #8 of 10 (permalink) Old 03-16-2014, 10:39 AM
skip the video to about 1050. It's the same pressure style clip that the lower cv uses so it just pulls out.
post #9 of 10 (permalink) Old 03-16-2014, 11:44 AM Thread Starter
Okay I figured it out. The splines inside of the differential case are stripped. Any clue where I can find one and what it is called?
post #10 of 10 (permalink) Old 03-16-2014, 01:40 PM
You can get the whole output section of the front gear case from the dealer and replace it. Or you can find a used diff and swap it out. P/N 3234531 and retails at about $170
2009 trailblazer 330 Fan Problems kenczar ATV Repair and Maintenance 2 07-12-2013 08:23 PM
2009 550 XP with start, idle and run problems lcvdvm ATV Repair and Maintenance 3 10-12-2012 07:37 PM
2009 sportsman 300 problems KPBrooks ATV New Members 2 09-21-2011 02:26 PM
New here- 2009 850xp problems highcountry1 ATV General Discussion 6 09-14-2010 05:15 AM
2009 850 xp eps steering problems bobwhitecar ATV New Members 2 12-12-2009 07:48 AM
