07 Sportsman 500 efi fuel power - Polaris ATV Forum
post #1 of 4 (permalink) Old 01-15-2016, 02:49 PM Thread Starter
fmeeks's Avatar
I am a newbe here, so if this is not in the correct place, sorry.
I have an 07 sportsman 500 efi, when I am testing the plug to the fuel pump, the meter flashes 13 to 14 volts when you turn the key on and then it drops to almost nothing.
The only problem I am having is no constant power for the fuel pump.
Can anyone help with this.
I have tested the plug using different grounds.
The atv just died while riding it a few weeks back.
Thanks for any help
fmeeks is offline
post #2 of 4 (permalink) Old 01-15-2016, 03:40 PM
4getful2's Avatar
After the pump has pressurized the line, the pump regulator kicks in and senses full pressure and starts shutting off the pump. And I don't think you can just remove the fuel line at the injector, cause it should sence low pressure and shut the pump off then as well.
Just unplug the elect. connector at the pump and see what the voltage is, should be the same as battery voltage.
for testing purposes, you really need to rig up an inline pressure gauge, any ol' cheapy pressure gauge will do as long as it can handle petroleum liquid and goes to at least 50 lbs. I think minimum test pressure is 38 lbs.
Check all your connections and make sure they are clean.
'08 Sportsman 500HO efi
'14 RZR 800 trail
'03 sportsman 500HO (gone)
'14 Massimo 800
'08 Hisun 700(gone)
'02 expedition 425(gone, but missed)
'98 Sport 400 (gone)
4getful2 is offline
post #3 of 4 (permalink) Old 01-15-2016, 04:19 PM Thread Starter
fmeeks's Avatar
Thanks for your reply
When I unplugged the pump and tested the plug, that is when I was getting good voltage (just a quick enough for me to read it on a meter when I turn the key on) and the voltage would go to nothing.
I also have the fuel line disconnected from the fuel tank
I just put a new battery in it. I tested the battery and it has a good charge.
fmeeks is offline
post #4 of 4 (permalink) Old 01-25-2016, 01:34 PM Thread Starter
fmeeks's Avatar
I got a new PCM
Still doing the same thing.
If I unplug the pump at the power supply connector, I get a flash of 13 volts. It is just enough to feel the pump pulse and able to get a reading on the meter.
Can anyone please help. If not I will have an 07 sportsman for sale (parts machine)
Thank you for you help
fmeeks is offline
Sportsman 500 EFI HO cutting off ParkwayAG ATV General Discussion 1 01-10-2016 10:51 AM
2000 Polaris sportsman hand brake lever RvL3RN ATV Brakes & Suspension 7 01-05-2016 10:56 AM
2004 700 efi fuel rail issue JohnHenry Polaris Sportsman 4 01-02-2016 04:46 PM
Sportsman 800 EFI HO Instrument Panel rebelyellNC 2008 3 12-30-2015 08:04 PM
2010 Sportsman 500- No Electrical Power Dude89 Polaris Sportsman 2 12-13-2015 04:58 PM
