Winch Help - Polaris ATV Forum
post #1 of 3 (permalink) Old 01-28-2016, 12:13 PM Thread Starter
Natureboy's Avatar
Winch Help
I've had the winch in my signature for 5 years now, 90% of the time it is just used for plowing. The last couple of times I plowed I noticed it moving really slow. The battery is good, checked connections and all were good. The next time I used it all it did was click, no in - no out. Still needing to plow I swapped an old 2000# Champion winch in without changing anything else and everything works as it should.
Today I hooked up the KFI to an in-out switch and a less than fully charged battery. Tried both in & out and it worked, although seemed a little slow. I don't know a lot about the internal winch workings, so my questions are if I take it apart-what should I look for as far as fixing it? Or am I wasting my time and 5 years is about the lifespan of a winch? Thanks for reading.
Natureboy is offline
post #2 of 3 (permalink) Old 01-28-2016, 01:35 PM
MustBeNice's Avatar
It's hard to say if "it's worth it or not", until you open it up to look.
I'd look for rust, dust (from worn brushes) or worn mechanical parts for starters.... I'm guessing brushes or brush dust causing "grounding/short circuit" type issues.
After disassembly, I'd...
1) Clean it out, by blow it out with compressed air hose and/or electric contact cleaner
2) Re-lube anything that should be lubed (bushings, gear teeth, ect), with a light coat with dielectric grease as at 5 years old it may gave dried out.
3) Re-assemble and test!!
Note: Should you find any rusty components, clean them up with steel wool.
Good Luck!
Matthew "MustBeNice"
MustBeNice is offline
post #3 of 3 (permalink) Old 01-28-2016, 02:00 PM Thread Starter
Natureboy's Avatar
Thank you.
Using ATV winch to help Mom with sciatica...please read toonces ATV General Discussion 23 01-28-2016 05:23 PM
Installing warn winch. ?? about wiring. jared72 ATV General Discussion 3 01-17-2016 11:04 AM
winch question? dusted800 ATV General Discussion 10 01-13-2016 04:07 AM
How to mod an XP winch mount to fit a Superwinch G2BC ATV Repair and Maintenance 2 01-06-2016 06:56 AM
Winch reels in slow, sometimes not at all Polaris4you Polaris Sportsman 8 12-30-2015 04:45 AM
