eps code 520230 31 - Page 5 - Polaris ATV Forum
post #41 of 49 (permalink) Old 04-19-2016, 06:48 AM
mvn
mvn's Avatar
Weird readings. Are you getting these readings with the EPS working?
Have a look at the attached for reference purposes.
Mark
2012 850HO Touring EPS Pearl White
27" ITP Blackwater Evolution radials on 14" ITP Black Ops wheels
Ricochet skid plates & A-arm guards
Rubberdown 1 1/2" lift
Cecco frame braces
JC Capri bushings
Rotopax fuel packs on custom mounts
Garmin 60CSx with Ram mount
Polaris 2500# winch with synthetic rope
Polaris front & rear brush guards
Polaris bar & thumb heaters
Polaris passenger grip heaters
NGK (6043) ILZKAR7A10 plugs
Good, fast, cheap.....pick 2!
mvn is offline
post #42 of 49 (permalink) Old 04-19-2016, 07:45 PM Thread Starter
gat
gat's Avatar
no. i tested them with the code on, eps off line and not working. im hoping its a bad connection somewhere. what are your thoughts? is the digital wrench trouble shooting something i can do?
2011 sportsman xp eps stealth black
sti hds se wheels
27" swamplite tires
1" spring spacers front and back
polaris deluxe rear bumper brushguard
polaris extreme front brushguard
lock & ride front cargo box
Polaris steel rear rack extender
aluminum products a-arm gaurds
aluminum products skid plates
Polaris hand/thumb warmers
polaris 2500lb winch
jc capri bushings
14" led light bar
k&n filter
gat is offline
post #43 of 49 (permalink) Old 04-20-2016, 06:19 AM
mvn
mvn's Avatar
Digital Wrench in Polaris' electronic service tool used by dealers.....typically huge $$$'s. That being said, you really need to verify the following when the key is on and the EPS is offline....
1. 2 position power connector on EPS unit...orange should show system voltage when referenced to brown wire (ground).
2. 3 position signal connector on EPS unit...orange should show system voltage when referenced to any ground or brown wire.
3. With 3 position signal connector disconnected, measure resistance across green and yellow wire (just like you did at the diagnostic connector). With key on, what do you see at this connector?
Honestly, there's really not much to this system. Assuming your pod display is working correctly, I don't think you have a major canbus issue other than a connection issue to the EPS unit. If everything checks out, you may have to resort to taking it to a dealer you trust. If I was any closer to you, I'd come over and give you a hand!
Mark
I just thought of something else. In the electrical diagram I previously posted, there is splice where the canbus network is interconnected to the ecm, pod and eps. I'm not sure where it is but see if you can verify that everything is ok there.
Cecco frame braces
JC Capri bushings
mvn is offline
post #44 of 49 (permalink) Old 04-27-2016, 04:59 PM Thread Starter
gat
gat's Avatar
so a quick follow up. i found it. there is a relay that runs on top of the left hand side of the frame. the fith time i checked it the eps light went away. i pried it apart, cleaned it up and put it back. eps fixed.
sti hds se wheels
27" swamplite tires
jc capri bushings
14" led light bar
k&n filter
gat is offline
post #45 of 49 (permalink) Old 04-27-2016, 05:51 PM
mvn
mvn's Avatar
OK, fingers crossed! It's usually the simple stuff!
Mark
Cecco frame braces
JC Capri bushings
mvn is offline
post #46 of 49 (permalink) Old 04-28-2016, 09:10 PM Thread Starter
gat
gat's Avatar
Mark
thank you for your time and help. much appreciated.
sti hds se wheels
27" swamplite tires
jc capri bushings
14" led light bar
k&n filter
gat is offline
post #47 of 49 (permalink) Old 04-29-2016, 05:52 AM
mvn
mvn's Avatar
Mark
No problem, glad you found the issue. So is the relay you reference part of the fuse/relay block or is it all by itself somewhere in the harness? I just reread the service manual and it clearly states that the EPS relay IS NOT located in the main fuse/relay box. So....the relay you found in the harness, if that's where you found it, is in fact the EPS relay!
Mark
Cecco frame braces
JC Capri bushings
mvn is offline
post #48 of 49 (permalink) Old 05-05-2016, 09:04 PM Thread Starter
gat
gat's Avatar
it is in the harness. i need a damn book! there is a eps relay in the box as well, i just assumed. this must be a common if not expected problem since they sell a rebuild kit for the plug with the new relay.
sti hds se wheels
27" swamplite tires
jc capri bushings
14" led light bar
k&n filter
gat is offline
post #49 of 49 (permalink) Old 02-10-2017, 07:15 AM
cbroccolo's Avatar
Hey Mark, I'm having issues with my EPS as well. I reviewed this thread and have been following your troubleshooting steps...I have power to the EPS via the 2 pin connector and also verified I have power on the Orange pin for the 3 pin com's connector... So I started with the resistance check between the yellow and green wire, I was seeing 120 ohms with the key off as per the attachment you added to this thread. So I started to cut out the harness and trace it back. I narrowed down the 120ohms to be coming from my display? Took that apart noticed some corrosion figured that was it but no joy still seeing 120 ohms with the key off right at the yellow and green pins on the board in my display...any thoughts?
Carson
cbroccolo is offline
Tapped EPS Upper Steering Post Koodat Polaris XP 3 04-05-2016 08:31 AM
Close Ratio AWD - Difference between my 570 SP vs 570 EPS Guilow Polaris Sportsman 570 20 01-13-2016 02:21 PM
Polaris mid-model year release off road January 5, 2016 Sportsman5001996 ATV General Discussion 9 01-05-2016 03:46 PM
question about buying: same price Ace 570 vs sportsman 570 eps? xOUTLAWx ATV General Discussion 10 01-04-2016 12:57 PM
Discussion about EPS on future Polaris machines. gibbons025 ATV General Discussion 36 12-31-2015 04:06 AM
