clutch hanging up - Page 2 - Polaris ATV Forum
post #11 of 14 (permalink) Old 05-11-2017, 05:58 PM
cariboo's Avatar
instead of water you can use grease
cariboo is offline
post #12 of 14 (permalink) Old 05-11-2017, 07:12 PM
Deucer's Avatar
Good idea with grease. The first time I tried the hydraulic trick I used oil. It came off ok but made quite a mess to clean up. I used water several times after that. Less cleanup. Once I got the clutch off my 850 the first time, it has come off easy every time from then on.
I will use the grease the next time a get a real stubborn clutch.
D
Deucer is offline
post #13 of 14 (permalink) Old 05-12-2017, 01:32 AM
Banned
aknawful's Avatar
Grease makes a mess. You'll have to get it all out before putting clutch back on
aknawful is offline
post #14 of 14 (permalink) Old 05-12-2017, 04:52 AM
wkeggenhoff's Avatar
Heat the rear clutch sheave with a heat gun on high setting. Expands the aluminum. Put some tension on puller bolt first then heat it will just pop off. Will expand .001-.002" be inch of bore. Same can be said with cooling a part with dry ice or liquid nitrogen. Shrinks the bore or shaft in size
2017 Xp 1000 Sportsman LE Matte Cooper
2008 843cc Yamaha Grizzly
wkeggenhoff is offline
Oil Help lancons23 Polaris Sportsman 570 47 12-20-2018 04:42 AM
Sportsman 500 X2 Dlx 2007 drive clutch hitting belt cover FredBurfle ATV Repair and Maintenance 1 02-23-2017 08:39 PM
2014 900 Clutch Issue Dknut ATV General Discussion 0 10-18-2016 08:30 AM
Sportsman 500 clutch questions.. tommy2fast ATV Repair and Maintenance 9 03-09-2016 06:38 AM
Clutch rebuild expenses vs. new clutch JohnHenry Polaris Sportsman 12 01-09-2016 09:12 AM
