2010 Polaris sportsman 850 co eps - Polaris ATV Forum
 1Likes
post #1 of 13 (permalink) Old 02-27-2018, 05:30 PM Thread Starter
hunter_dad_jose's Avatar
Having a problem with eps light flashing after bout 10min of riding. I got new battery an relay an greased connections an it still flashes. What else could it be an also would it cause more problems riding with it flashing?
Sent from my SM-G950U using Tapatalk
hunter_dad_jose is offline
post #2 of 13 (permalink) Old 02-28-2018, 01:07 AM
bp405's Avatar
What do you have for DC voltage across the battery terminals @3,000 rpm?
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 13 (permalink) Old 02-28-2018, 09:39 AM Thread Starter
Not sure but I have noticed when I do rev it up the eps light does go off.
post #4 of 13 (permalink) Old 02-28-2018, 01:53 PM
Gulf550's Avatar
I agree with bp405. Check the battery voltage while the bike is running. My voltage regulator went bad on my 2010 and had similar problems. At idle it was putting out 18 volts and as the rpms were varied, the voltage would drop. I believe it should stay constant at 14 VDC.
Gulf550 is offline
post #5 of 13 (permalink) Old 02-28-2018, 03:02 PM Thread Starter
So revving it up an eps light go off a sign of possibly a bad voltage regulator?
post #6 of 13 (permalink) Old 02-28-2018, 04:40 PM
Gulf550's Avatar
I would say yes on the voltage regulator but there is also a possibility it could be a sator going. That's why you should measure the voltage across the battery when its running. You should have a Code.
Gulf550 is offline
post #7 of 13 (permalink) Old 02-28-2018, 07:23 PM Thread Starter
Yeah that's what's crazy is there is no code coming up. Stoping to get a voltage meter and go from there. I appreciate your time and info.
post #8 of 13 (permalink) Old 03-01-2018, 11:17 AM Thread Starter
I was able to check the voltage across battery when running at 3000rpm an it's 43 an now there's a code 168 3 an that's high voltage. So is that voltage regulator or starter
post #9 of 13 (permalink) Old 03-01-2018, 04:38 PM
Gulf550's Avatar
Voltage regulator
hunter_dad_jose likes this.
Gulf550 is offline
post #10 of 13 (permalink) Old 03-09-2018, 10:45 AM Thread Starter
Voltage regulator
That's what it was the voltage regulator. Thank u for the info an now I got another problem after taking it out riding. It started to smoke white but not as I was out riding just when I started it up to load on trailer. It never overheated an all fluids was good an it idles good an sounds as it should could it be water pump?
ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) FOR SALE KLCFLC Polaris Sportsman 2 02-18-2019 05:57 PM
2016 Polaris Sportsman 850 SP - Catvos Lift and Tires Weist318 Polaris Sportsman 6 11-23-2016 05:07 PM
F/S: 2010 Sportsman 850 XP Browning Camo Hunter Pkg - PA bonsey ATVs For Sale 4 09-27-2016 02:44 AM
Sportsman 850 SP EPS indicator question Viper1357 ATV General Discussion 5 09-11-2016 07:46 AM
Shock interchange TDMax Polaris XP 7 07-13-2016 05:21 PM
