2008 polaris 500 h.o. efi front diff. - Polaris ATV Forum
post #1 of 3 (permalink) Old 03-06-2019, 10:20 AM Thread Starter
Jason Wright's Avatar
I have a 2008 Polaris 500 ho efi 4x4 that now has a hole in the front diff. I need to replace the diff.. Is there any diff that will cross over to this machine from another machine? thanks.
Jason Wright is offline
post #2 of 3 (permalink) Old 03-06-2019, 10:27 AM
bp405's Avatar
Looks like these models share your front diff:
2009 SPORTSMAN 500 EFI A09MN50AN/AX DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09MN50AN/AX (49ATVGEARCASE1332568) 1332568
2007 SPORTSMAN 500 EFI A07MH50AB/AL/AQ/AX/AY/AZ/MN50AF/AN/AT/AY GEARCASE, FRONT (ACTIVE DESCENT CONTROL)(If Built After 7/17/06) - A07MN50AF/AN/AT/AY (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN 500 EFI SCANDINAVIAN A08MH50SS/SQ DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08MH50SS/SQ (49ATVGEARCASE1332568) 1332568
2009 SPORTSMAN 500 EFI TRACTOR A09MN50ET DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09MN50ET (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN 500 HO EFI A08MN50AF/AN/AQ/AR/AS/AT/AW/AX DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08MN50AF/AN/AQ/AR/AS/AT/AW/AX (49ATVGEARCASE1332568) 1332568
2007 SPORTSMAN 800 EFI A07MH76AL/AQ/AX/AY/AZ/A2/MN76AF/AT/AY GEARCASE, FRONT (ACTIVE DESCENT CONTROL)(If Built After 7/17/06) - MN76AF/AT/AY (49ATVGEARCASE1332568) 1332568
2009 SPORTSMAN 800 EFI 6X6 A09CL76AA DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09CL76AA (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN 800 EFI SCANDINAVIAN A08MH76SS/SF DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08MH76SS/SF (49ATVGEARCASE1332568) 1332568
2009 SPORTSMAN 800 HO EFI A09MN76AX/AZ DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09MN76AX/AZ (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN 800 HO EFI A08MN76AF/AL/AQ/AR/AS/AT/AX DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08MN76AF/AL/AQ/AR/AS/AT/AX (49ATVGEARCASE1332568) 1332568
2009 SPORTSMAN TOURING 500 EFI A09DN50AB/AZ DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09DN50AB/AZ (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN TOURING 500 EFI A08DN50AF/AS/AW/AZ DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08DN50AF/AS/AW/AZ (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN TOURING 500 EFI QUAD A08DN50EA DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08DN50EA (49ATVGEARCASE1332568) 1332568
2009 SPORTSMAN TOURING 500 EFI QUAD A09DN50EA DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09DN50EA (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN TOURING 800 EFI A08DN76AF/AG/AH/AL/AJ/AS DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08DN76AF/AG/AH/AL/AJ/AS (49ATVGEARCASE1332568) 1332568
2009 SPORTSMAN TOURING 800 EFI A09DN76AB/AL/AY DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09DN76AB/AL/AY (49ATVGEARCASE1332568) 1332568
2009 SPORTSMAN TOURING 800 EFI INTL A09DN76FC DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09DN76FC (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN TOURING 800 EFI INTL A08DN76FC DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08DN76FC (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN X2 500 EFI A08TN50AT/AX/AZ DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08TN50AT/AX/AZ (49ATVGEARCASE1332568) 1332568
2007 SPORTSMAN X2 500 EFI A07TH50AL/AQ/AU/AZ/TN50AF/AS/AU GEARCASE, FRONT (ACTIVE DESCENT CONTROL) - A07TN50AF/AS/AU (49ATVGEARCASE1332568) 1332568
2009 SPORTSMAN X2 500 EFI A09TN50AX/AZ DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09TN50AX/AZ (49ATVGEARCASE1332568) 1332568
2009 SPORTSMAN X2 500 EFI QUAD A09TN50EA DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09TN50EA (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN X2 500 EFI QUAD A08TN50EA DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08TN50EA (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN X2 700 EFI A08TN68AX/AZ DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08TN68AX/AZ (49ATVGEARCASE1332568) 1332568
2007 SPORTSMAN X2 800 EFI A07TH76AU/TN76AF/AL/AU GEARCASE, FRONT (ACTIVE DESCENT CONTROL) - A07TN76AF/AL/AU (49ATVGEARCASE1332568) 1332568
2009 SPORTSMAN X2 800 EFI A09TN76AL/AX/AZ DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A09TN76AL/AX/AZ (49ATVGEARCASE1332568) 1332568
2008 SPORTSMAN X2 800 EFI LE A08TN76AA/AQ DRIVE TRAIN, FRONT GEARCASE and MOUNTING - A08TN76AA/AQ (49ATVGEARCASE1332568) 1332568
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 3 (permalink) Old 03-06-2019, 10:46 AM Thread Starter
awesome.. thank you
05 Sportsman 700(non efi) front diff Dhernandez Polaris Sportsman 3 02-11-2019 12:10 PM
VIN - Sportsman 500 or 500 HO? das86turbo ATV Repair and Maintenance 7 01-02-2019 06:58 AM
Sportsman 600 Primary Help Needed TooSlo ATV Repair and Maintenance 8 07-23-2018 11:58 AM
Part number for factory winch, 2013 sportsman 500 HO? Smokinu454 ATV Gear and Gadgets 4 11-28-2017 05:38 AM
2008 Polaris sportsman 500 touring brushguards natale ATV New Members 1 03-27-2017 06:07 PM
