2015 Ranger Diesel Crew - Polaris ATV Forum
post #1 of 6 (permalink) Old 03-29-2019, 01:05 PM Thread Starter
Sroth1701's Avatar
High Gear Does Nothing. Low gear is fine. Runs fine. Any Suggestions?
Sroth1701 is offline
post #2 of 6 (permalink) Old 03-29-2019, 01:45 PM
bp405's Avatar
Going to have to pull the tranny and open it up. You lost something internally!!!
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 6 (permalink) Old 03-31-2019, 06:22 AM Thread Starter
Sroth1701's Avatar
What's the odds it might be a linkage adjustment issue?
post #4 of 6 (permalink) Old 03-31-2019, 08:27 AM
Liftedpsd's Avatar
Does it indicate it’s in high in the cluster? On the rear passenger side take off the linkage from the trans. Manually shift it and see if you can get high to engage.
Liftedpsd is online now
post #5 of 6 (permalink) Old 03-31-2019, 10:40 AM
bp405's Avatar
You could hope!!! But if you have every other gear then something's broke inside!!!!
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #6 of 6 (permalink) Old 03-31-2019, 11:41 AM
Liftedpsd's Avatar
It could be the linkage isn’t going all the way into high since high is the first gear and farthest gear along with park.
Any Polaris deep parts connections? TDMax Polaris Sportsman XP 1000 10 02-09-2019 09:13 AM
2015 Sportsman etx barely will run, pops, stalls PaYankee Polaris Sportsman 12 10-21-2018 04:38 PM
Ignition switch 570 sportsman Fivespeed ATV New Members 4 12-15-2017 07:03 AM
