2003 Polaris Sportsman 500 no start with back fire. - Polaris ATV Forum
post #1 of 6 (permalink) Old 05-21-2019, 01:37 PM Thread Starter
dougreig's Avatar
Hello. I am in need of some mechanical help.
I just ran into a puzzling issue with my 2003 polaris 500. The 4x4 had been sitting for several months. I recently started it and moved it around a little. I decided to clean it up so I pressure washed. Once I was finished washing, I tried to start the bike. Thats when I had a no start with backfire. So I let it set over night, thinking some component of importance got wet. Today is the same issue. I think the back fires are coming for the carburetor. It did start once, but only idled for a few seconds. I have good ignition fire at the spark plug, I went thru the carburetor, I checked the fuel for water. All seems to be ok. I tried a little starting fluid. No go!
Any advice of what to try next? Thanks.
dougreig is offline
post #2 of 6 (permalink) Old 05-21-2019, 02:31 PM
Try a new spark plug - plugs can go bad when setting unused inside an engine
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is online now
post #3 of 6 (permalink) Old 05-21-2019, 02:50 PM
Metro500's Avatar
Sounds like it is flooding out the carb to excess fuel. Maybe try shutting off the fuel, then drain the bowl on the carb. Then try starting with just starting fluid (not too much). See if it runs for a short time with this. If it does better, need to figure out why it is getting too much fuel. Float might possibly have a hole not shutting off flow of fuel. Good luck and let us know.
Metro500 is offline
post #4 of 6 (permalink) Old 05-23-2019, 06:33 AM Thread Starter
dougreig's Avatar
Thanks. I have plenty of fire with the spark plug. I will change the small inline fuel filter and fuel pump and try it again.
dougreig is offline
post #5 of 6 (permalink) Old 05-23-2019, 06:39 AM Thread Starter
dougreig's Avatar
Thanks. I dissassembled the carburetor, checked components, all seemed to be functioning correctly. The problem started after I pressure washed the bike. I will change the inline fuel filter and the fuel pump while I have the bike partically dissassembled. I let you know. Thanks for the help!
dougreig is offline
post #6 of 6 (permalink) Old 05-23-2019, 07:59 AM
Backfire from the carb usually is an indication of a lean condition, tight intake valves or if it's an electrical condition causing the problem, a bad spark plug is the first suspect.
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
Service manuals cookies ATV Repair and Maintenance 1085 Yesterday 04:36 AM
Polaris Ground Cable Lenght Hondov65 ATV General Discussion 3 02-06-2019 08:46 AM
2003 Sportsman 500 turns over, wont start (on pull start either) Smoknjoe ATV New Members 0 09-13-2018 05:47 AM
Sportsman 500 clutches Pluto75 ATV Repair and Maintenance 3 06-21-2018 06:26 AM
