2014 sportsman starter replacement - Polaris ATV Forum
 1Likes
  • 1 Post By polman500
post #1 of 6 (permalink) Old 07-16-2019, 12:11 PM Thread Starter
Lancewfcody's Avatar
Trying to replace starter ,but the bolt holding it in is up against the frame.theres a hole in frame to remove bolt ,but it is an inch below the hole.how do I pry engine up enough to remove it without breaking anything, or do I need to remove something else?
Thanks for your help.
Lancewfcody is offline
post #2 of 6 (permalink) Old 07-16-2019, 03:37 PM
What model are you working on? Sportsman 90, 400, 550, 570, 800, 850 or ACE?
latebird is online now
post #3 of 6 (permalink) Old 07-16-2019, 06:19 PM Thread Starter
Sorry,its a 570.
post #4 of 6 (permalink) Old 07-17-2019, 05:10 AM
Her's the instructions copied from the service manual:
Starter Motor Removal
1. Remove the seat, left side panel, and disconnect the battery.
2. Remove the (+) positive wire (A) from the starter motor terminal.
3. Remove the upper starter motor fastener (1) securing the starter motor and (-) negative battery cable to the engine. Completely loosen the lower starter motor fastener.
NOTE: The (-) negative battery cable is mounted to the the engine using the upper starter mounting bolt.
4. Remove the starter from the engine.
Pics of your dilemma might help.
I personally have not changed a starter motor on a 570, so I am not familiar with the problem you have encountered.
post #5 of 6 (permalink) Old 07-17-2019, 09:39 AM Thread Starter
Got it,had to pry engine up with bar enough to get bolt to come out .Thanks.
post #6 of 6 (permalink) Old 07-17-2019, 09:50 AM
That's not how you do it. You take the + cable off.
Take the top bolt and - cable off.
Then you loosen the bottom bolt all the way and take the starter and bottom bolt out together.
When you reinstall, you have to put the bottom bolt in the starter first and then put the starter and bolt into position to get the bottom bolt started again.
indyred570 likes this.
polman500 is online now
