2015 Polaris 570 EFI EPS Sportsman Fuel Pump Issues - Polaris ATV Forum
post #1 of 15 (permalink) Old 08-19-2019, 06:13 AM Thread Starter
JKLittle's Avatar
Need Help! I’m on my 3rd Fuel Pump. Pump 2 lasted 5 hours, pump 3, 1 hour. Pump 3 is coming on but not pumping any gas. The battery had low voltage. Could that be an issue? Will that effect the Fuel pump from sending fuel?
I charged the battery and still wouldn’t start. Then this morning after turning over multiple times, it started up. Very confused. Any help would be appreciated.
JKLittle is offline
post #2 of 15 (permalink) Old 08-19-2019, 07:13 AM Thread Starter
JKLittle's Avatar
Also had low battery. Would this not let the pump send fuel? It turns over fine but not pumping any fuel.
JKLittle is offline
post #3 of 15 (permalink) Old 08-19-2019, 07:17 AM
bp405's Avatar
Will it run right now???? If it will read the voltage at the battery. At idle and at 3,000rpm. Should read 13.5-14.5vdc. My initial thoughts are the machine is running in an over voltage state and blowing the pumps prematurely.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #4 of 15 (permalink) Old 08-24-2019, 04:56 AM Thread Starter
JKLittle's Avatar
It was running again. Drove it 3-days in a row for 20 minutes then no go again. The pump runs but it doesn’t pump fuel. After turning the key and turning engine over, after it doesn’t start. I turn the key off and it clicks rapidly back at the carburetor on one of those sensors. Not sure what the deal is there. I will check the volts on the battery. The display reads that it’s low. 10.4
JKLittle is offline
post #5 of 15 (permalink) Old 08-24-2019, 05:36 AM
bp405's Avatar
Well you have to get the battery and charging system right before go any further with a diagnosis. The battery needs to be charged and load tested. Once the battery is operating optimally you need to check the charging system.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #6 of 15 (permalink) Old 08-24-2019, 10:18 AM Thread Starter
JKLittle's Avatar
Just put new battery in, 100% charged, same outcome. Turns over fine but the fuel pump isn’t pumping any fuel. The pump runs as soon can hear it whining, but no fuel is sent.
JKLittle is offline
post #7 of 15 (permalink) Old 08-24-2019, 02:26 PM
bp405's Avatar
When you say fuel is not sent how do you know????
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
post #8 of 15 (permalink) Old 08-24-2019, 03:52 PM Thread Starter
JKLittle's Avatar
Because I pulled the fuel line off of the rail and put it in a bucket, turned the key and there was no fuel coming thru. I ended up putting the old pump assembly back on as it would pump, just wouldn’t pump the needed pressure. As before, it did pump fuel. I’m thinking that that tells me that I just got a bad replacement pump. Maybe my low battery previously damaged the pumps.
JKLittle is offline
post #9 of 15 (permalink) Old 08-24-2019, 03:56 PM Thread Starter
JKLittle's Avatar
I noticed that my new assembly was about 1” shorter than my original assembly. I think it’s actually an assembly for a Polaris 570 Ranger, not a Sportsman 4-wheeler. Not sure if that makes a difference or not. The new assembly doesn’t rest on the bottom of the tank. (or push up on the spring post)
JKLittle is offline
post #10 of 15 (permalink) Old 08-24-2019, 04:36 PM
bp405's Avatar
Well if you're getting pump whine and no fuel I would suspect a bad connection in the tank!!
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is offline
