My issue is, it will turn over but not start. I started it about 3 weeks ago and let it run for awhile, did not actually ride it. The battery is good,the digital readings on the speedometer come on, air filter is clean,lights and winch work. I replaced the fuel filter and spark plug today, nothing changed. I did notice that it doesn't make that sound when you first turn the key before you start it. Did the electronic fuel pump or sending unit go out or something? Thanks for any help in advance!
