Rear Diff/ Trans Oil - Polaris ATV Forum
ATV Oil, Lubrication & Filter Discussions for Engine Oils, Gear Oils, Lubrication & Filter, etc.
post #1 of 3 (permalink) Old 04-23-2018, 09:35 AM Thread Starter
teejam171's Avatar
Just purchased an 18 base 570 and would like to change all the fluids. Is the Trans fluid separate from the Rear diff. fluid? Apologies if this is probably a silly question but I am new to this. Thanks
teejam171 is offline
post #2 of 3 (permalink) Old 05-04-2019, 02:48 AM
rccrazywv's Avatar
On the sportsman 570 the transmission and rear diff fluid are the same.
Sent from my moto e5 play using Tapatalk
rccrazywv is offline
post #3 of 3 (permalink) Old 05-04-2019, 06:14 AM
indyred570's Avatar
Check out the 'Owners Manual', quite a bit of good information in there. Yes the transmission & rear diff is one unit on the 570, it takes 32oz of AGL fluid.
2014 Sportsman 570
Powermadd Hand Guards
Viper Elite 3000 Winch/KFI mount
Denali Snow Plow
Polaris HD Front Springs
Kenda Executioners
Ricochet A-arm guards
QSC clutch kit
indyred570 is offline
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > ATV Oil, Lubrication & Filter
Tags
570, fluids, oil
2003 sportsman 700 LH footboard needed razorsharp ATV Parts Wanted 8 11-07-2017 01:37 PM
double checking if this oil goes in transmission and rear diff willchap86 ATV Repair and Maintenance 6 10-26-2016 02:25 PM
