ATV Oil, Lubrication & Filter Discussions for Engine Oils, Gear Oils, Lubrication & Filter, etc.
post #1 of 4 (permalink) Old 09-07-2019, 05:26 AM Thread Starter
Whistlingdeuce's Avatar
2008 Sportsman 800 trans vs rear diff fluid
I'm sure this has been covered but I did a search and can't find what I'm looking for.
I have an '08 Soortsman 800 and want to change the trans and rear fluid. I have the large service manual and it looks like I am getting mixed information from it as to what fluid to use. I've changed both before but I don't remember this being an issue.
The manual says in the maintenance section to use "ATV angle drive fluid" for rear gear case but 2 pages later in actual section to show procedure it says to use "premium synthetic AGL gearcase fluid".
I know these things can be very picky about the correct fluid can someone please let me know the correct fluid to use?
Thank you as always.
Whistlingdeuce is offline
post #2 of 4 (permalink) Old 09-07-2019, 03:21 PM
Jason537's Avatar
Synthetic 75w-90
Hers 2014 570 sportsman,
2" AtvE lift
His 2013 850xp LE,
28" Zillas
1.5" lift
LTE slip-on,
Welded timing gear
Jason537 is offline
post #3 of 4 (permalink) Old 09-07-2019, 07:50 PM
Yep, your 2008 has a separate tranny and rear gearcase. Any good 75-90 or 80-90 gear oil will do . If using Polaris juice... Angle drive fluid.
polman500 is online now
post #4 of 4 (permalink) Old 09-11-2019, 08:46 AM
Just to be clear... gear oil in the rear gearcase/diff. Tranny oil in the tranny.
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > ATV Oil, Lubrication & Filter
