2005 500ho oil - Polaris ATV Forum
ATV Oil, Lubrication & Filter Discussions for Engine Oils, Gear Oils, Lubrication & Filter, etc.
post #1 of 8 (permalink) Old 08-24-2014, 11:21 AM Thread Starter
redneckracer01's Avatar
2005 500ho oil
Has anybody tried running brad Penn high zinc oil I can get 50 weight for a good price and I ride a lot in the Arizona summer do you think this Will be ok
redneckracer01 is offline
post #2 of 8 (permalink) Old 08-24-2014, 11:44 AM
KD0AXS's Avatar
Looks like it comes in a straight 50 grade or 20W-50. No way would I use the straight 50 grade. I suppose the 20W-50 would be ok in Arizona. Ideally you should use a 0W-40, 5W-40, or 5W-50.
Sent from my HTCONE using Tapatalk
2008 Polaris Scrambler 500HO 4x4
Rear Rack
Pro Armor Front Bumper
Trailer Hitch
Clutch Case Snorkel
2500 lb Warn Winch
48" Cycle Country Plow
KD0AXS is offline
post #3 of 8 (permalink) Old 08-24-2014, 12:05 PM
al53's Avatar
if you want high zinc..just use some 5-50 or 5-40 and get some Lucas hi zinc additive....I my self use 3 oz of moly in oil change sine the moly adheres to metal so there is lube there before oil gets up in rockers...
here is some hi zinc additive.... Engine Break-In Oil Additive | Lucas Oil Products, Inc.
it says for break in period or just a oil additive...
2002 Sportsman 500HO
1987 Suzuki LT250 4x4 The Beast
al53 is offline
post #4 of 8 (permalink) Old 08-24-2014, 12:15 PM Thread Starter
I'm sorry for my ignorance but why would you not use straight 50 I'm trying to learn as much as I can so any explanation would be greatly appreciated thank you
post #5 of 8 (permalink) Old 08-24-2014, 12:51 PM
5254's Avatar
Straight wright oils are really single dimensional. A multigrade such as 5W50 is much better. It is a 5 weight in tne cold temps, and a 50 weight in tbe hot temps.
Polaris does not recommend single grade oils.
5254 is offline
post #6 of 8 (permalink) Old 08-24-2014, 12:52 PM
al53's Avatar
the straight 50 is thick and since the 500 is a dry sump..it will be awhile before the oil gets thru the engine...why the oil tank..thats like your oil pan...a thinner oil like 5-40 will flow better when started and then per say thicken to 40W as engine gets heated...but will be a 5W when you start it to get oil flowing faster....
al53 is offline
post #7 of 8 (permalink) Old 08-24-2014, 01:55 PM Thread Starter
Thank you guys for the help
post #8 of 8 (permalink) Old 08-25-2014, 03:36 AM
KD0AXS's Avatar
Read through the "Motor Oil University" on BITOG. This will give you a much better understanding of motor oils.
http://www.bobistheoilguy.com/motor-oil-101/
Rear Rack
Trailer Hitch
Clutch Case Snorkel
2500 lb Warn Winch
KD0AXS is offline
Go Back   Polaris ATV Forum > Polaris ATV Technical Discussions > ATV Oil, Lubrication & Filter
2005 500HO electrical problem swva Polaris Sportsman 10 09-28-2014 08:56 AM
2005 atp 500ho matty2244 Polaris Sportsman 5 04-14-2014 09:30 AM
2005 sportsman 500ho ecm redneckracer01 ATV Repair and Maintenance 30 11-25-2013 02:05 PM
2005 sportsman 500HO Stator help fiercecivic ATV Repair and Maintenance 4 02-11-2013 06:57 AM
2005 700 EFI vs 2010-11 500HO chrisnwmsu Polaris Sportsman 9 02-28-2011 04:25 AM
