2003 sportsman 700 LH footboard needed - Polaris ATV Forum
ATV Parts Wanted Looking for a certain ATV Part? Post it up here.
post #1 of 9 (permalink) Old 10-25-2017, 01:18 PM Thread Starter
razorsharp's Avatar
Front of mine broken and the fender is flopping around and rubbing the coolant tank. Anyone know of a good source for used parts?
razorsharp is offline
post #2 of 9 (permalink) Old 10-25-2017, 03:13 PM
stave7119's Avatar
Check Ebay. Do a search for your machine then narrow it down. Powersports Nation is a seller I have dealt with in the past. There are a couple others too that I have gotten stuff from. Most are basically salvage yards for off road stuff.
Chances are that someone will have what you need!
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #3 of 9 (permalink) Old 10-30-2017, 02:04 PM Thread Starter
razorsharp's Avatar
Powersportsnation wants $103.00 for a used one. Ebay looks like the way to go.
post #4 of 9 (permalink) Old 10-30-2017, 03:52 PM Thread Starter
razorsharp's Avatar
Anyone know what years are compatible with a 2003. Manufacturers often make subtle differences in parts so you have to "upgrade". Will an 07 fit a 2003?
post #5 of 9 (permalink) Old 10-30-2017, 04:19 PM
stave7119's Avatar
Here is a list of what fits from the Polaris cross reference. Doesn't show the '07 Sportsman.
I think they made a body style change in 2005 for the full size sportsman models. The 6x6 doesn't change as often. Current body on the 6x6 has been the same since 2008 I think. Some of the others will be easy to find though. The trail boss and Magnums were plentiful.
SERIES 10 PPS PTV 6X6 REAR CAB and SEAT - C10CL50AA (4978707870A04)
2009 ATV TRAIL BOSS 330 BODY, REAR CAB and FOOTWELLS - A09CA32AA (49ATVCABRR08BOSS)
2008 ATV TRAIL BOSS 330 BODY, REAR CAB and FOOTWELLS - A08CA32AA (49ATVCABRR08BOSS)
2008 ATV SPORTSMAN 6X6 BODY, REAR CAB and SEAT - A08CL50AA (49ATVCABRR086X6)
2007 ATV TRAIL BOSS 330 CAB, REAR and SEAT - A07CA32AA (49ATVCABRRBOSS)
2007 ATV SPORTSMAN 6X6 CAB, REAR and SEAT - A07CL50AA (49ATVCABRR6X6)
2007 MIL SPORTSMAN 6X6 MV CAB, REAR and SEAT - A07CL50MA (49ATVCABRR6X6)
2006 ATV MAGNUM 330 4X4 CAB, REAR - A06CD32AA/AB/AC (4999201699920169A03)
2006 ATV TRAIL BOSS 330 CAB, REAR and SEAT - A06CA32AA/AB (4999202939920293A04)
2006 ATV SPORTSMAN 6X6 CAB, REAR and SEAT - A06CL50AA (4999201649920164A04)
2005 ATV TRAIL BOSS 330 QUADRICYCLE CAB, REAR and SEAT - A05CA32EA (4999200489920048A04)
2005 ATV SPORTSMAN 6X6 CAB, REAR and SEAT - A05CL50AA (4999201649920164A04)
2005 ATV TRAIL BOSS 330 REAR CAB and SEAT - A05CA32AA/AB/AC/FA (4994839483A04)
2005 ATV MAGNUM 330 2X4 REAR CAB and SEAT - A05CB32AA (4994889488A03)
2005 ATV MAGNUM 330 4X4 REAR CAB and SEAT - A05CD32AA/AB/AC (4994909490A03)
2005 MIL SPORTSMAN 6X6 MV CAB, REAR and SEAT - A05CL50MA (4995019501A04)
2004 ATV A04CA32AA TRAIL BOSS 330 REAR CAB and SEAT - A04CA32AA/AB/FA (4994839483A04)
2004 ATV MAGNUM 330 2X4 REAR CAB and SEAT - A04CB32AA/FC (4986188618A03)
2004 ATV MAGNUM 330 4X4 REAR CAB and SEAT - A04CD32AA/AB/AC/FB (4986268626A03)
2004 ATV A04CH42AA SPORTSMAN 400 REAR CAB AND SEAT - A04CH42AA/AE/AG (4986068606A03)
2004 ATV A04CH42AQ SPORTSMAN 400 REAR CAB AND SEAT - A04CH42AQ/AR/AS/AT/AV (4987258725A03)
2004 ATV A04CH50AA SPORTSMAN 500 REAR CAB AND SEAT - A04CH50AA/AC/AE/AG (4986088608A03)
2004 ATV A04CH50AQ SPORTSMAN 500 REAR CAB AND SEAT - A04CH50AO/AQ/AR/AS/AT/AV/AW/AX (4987288728A03)
2004 ATV SPORTSMAN 6X6 REAR CAB and SEAT - A04CL50AA (4986288628A04)
2004 ATV A04CH59AF SPORTSMAN 600 REAR CAB, SEAT AND MAIN FRAME - A04CH59AF/AH/AJ/AT/AV (4986108610A03)
2004 ATV A04CH59AK SPORTSMAN 600 REAR CAB, SEAT and MAIN FRAME - A04CH59AK/AL/AN/AQ/AW (4987318731A03)
2004 ATV A04CH68AU/CU SPORTSMAN 700 REAR CAB, SEAT and MAIN FRAME - A04CH68AP/AQ/AU/CU (4987468746A03)
2004 ATV A04CH68AC SPORTSMAN 700 REAR CAB/SEAT/MAIN FRAME - A04CH68AC/AF/AH/AJ/AT/AV (4986128612A03)
2004 ATV A04CH68AK SPORTSMAN 700 REAR CAB/SEAT/MAIN FRAME - A04CH68AK/AL/AN/AO (4987438743A03)
2003 ATV MAGNUM 330 2X4 REAR CAB and SEAT - A03CB32AA/FC (4975157515A03)
2003 ATV MAGNUM 330 4X4 REAR CAB and SEAT - A03CD32AA/AB/AC/FB (4975217521A03)
2003 ATV SPORTSMAN 400 REAR CAB AND SEAT - A03CH42AA/AB/AC (4975377537A03)
2003 ATV SPORTSMAN 500 HO REAR CAB AND SEAT - A03CH50AA/AB/AC/AD/AE/AH/AJ (4975417541A03)
2003 ATV SPORTSMAN 6X6 REAR CAB and SEAT - A03CL50AA (4975687568A04)
2003 ATV SPORTSMAN 600 REAR CAB, SEAT AND MAIN FRAME - A03CH59AA/AF/AG (4977187718A03)
2003 ATV SPORTSMAN 700 REAR CAB/SEAT/MAIN FRAME - A03CH68AA/AC/AF/AH/AL (4975557555A03)
2002 ATV 325 MAGNUM 2X4 HDS REAR CAB AND SEAT - A02CB32AA/AB/FC (4970107010A03)
2002 ATV MAGNUM 325 2X4 REAR CAB AND SEAT - A02CB32AA/AB/FC (4970107010A03)
2002 ATV 325 MAGNUM 4X4 HDS REAR CAB and SEAT - A02CD32AA/AB/AC/FB (4970147014A03)
2002 ATV MAGNUM 325 4X4 REAR CAB and SEAT - A02CD32AA/AB/AC/FB (4970147014A03)
2002 ATV MAGNUM 325 4X4 FREEDOM REAR CAB and SEAT - A02CD32AA/AB/AC/FB (4970147014A03)
2002 ATV SPORTSMAN 400 REAR CAB AND SEAT - A02CH42AA (4968536853A03)
2002 ATV SPORTSMAN 500 ALL OPTIONS REAR CAB AND SEAT - A02CH50 ALL OPTIONS (4967436743A03)
2002 ATV INT'L BIG BOSS 6X6 REAR CAB and SEAT - A02CL50AA/DA (4967986798A04)
2002 ATV SPORTSMAN 6X6 REAR CAB and SEAT - A02CL50AA/DA (4967986798A04)
2002 ATV SPORTSMAN 700 REAR CAB/SEAT/MAIN FRAME - A02CH68AA/AB/AC/CA/CB (4966346634A03)
post #6 of 9 (permalink) Old 10-30-2017, 05:07 PM
robk's Avatar
Powersportsnation.com posts stuff on ebay. You might get a better price. I bought a RZR roll cage for $300 shipped. They wanted $550 for it on their website.
robk is offline
post #7 of 9 (permalink) Old 10-30-2017, 05:23 PM
stave7119's Avatar
Yeah, everything I have gotten from them has been through an ebay listing. Never looked for stuff on the website.
post #8 of 9 (permalink) Old 11-06-2017, 03:50 PM
Phearless's Avatar
Not sure if you have found one or not, but I have one.
Phearless is offline
post #9 of 9 (permalink) Old 11-07-2017, 01:37 PM Thread Starter
razorsharp's Avatar
PM'd you Phearless.
Go Back   Polaris ATV Forum > Polaris ATV Classifieds > ATV Parts Wanted
ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) FOR SALE KLCFLC Polaris Sportsman 2 02-18-2019 05:57 PM
3280431 ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) KLCFLC ATV New Members 1 09-18-2017 07:52 PM
Sportsman 700 Crankshaft Brawndo ATV Parts Wanted 2 06-07-2016 05:18 PM
