18 sportsman 850 sp winch - Polaris ATV Forum
 1Likes
  • 1 Post By Sprotsman
post #1 of 6 (permalink) Old 08-01-2018, 06:32 AM Thread Starter
Braaaap_it's Avatar
Hi guys has anyone here bought a non Polaris winch and wired it into the existing wiring for the Polaris plug and play winches just curious on if it can be done because those polaris winches are not cheap thanks
Braaaap_it is offline
post #2 of 6 (permalink) Old 08-01-2018, 04:55 PM
Jheck1124@gmail.com's Avatar
Hello! Yes I bought a Warn Vintage winch for my Polaris. I also bought the warn mounting kit. I think I got them from motosport.com. It was an easy install and I mounted the winch controller in the front trunk. The only really modification was splicing the wires to the polaris wiring harness and that wasn't difficult either. The harness is right on the left handle bar. Hope this helps!
post #3 of 6 (permalink) Old 08-02-2018, 03:06 AM Thread Starter
Braaaap_it's Avatar
Yes it does thanks I just don’t want to spend the money on a Polaris winch and I’d rather not run a whole new harness if I can just use what’s there thanks a bunch
post #4 of 6 (permalink) Old 11-24-2018, 07:44 PM
Poca644's Avatar
Spoke with my dealer where I just bought my 2018 Polaris 570 and was told if you splice an aftermarket winch into the wiring harness and you have a future electrical issue. It voids your warranty. So your better to go with the factory winch. Kit comes with everything you need.
Poca644 is offline
post #5 of 6 (permalink) Old 11-25-2018, 04:47 AM
bp405's Avatar
although I think this is total I do get it!!! I've seen some real hack jobs by guys that have NO business working on wheelers or touching anything electrical. Not that I can see having to bring my wheelers in for any electrical work, I do plan on putting a warn winch on the 570.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #6 of 6 (permalink) Old 11-25-2018, 11:19 AM
Sprotsman's Avatar
You don’t need to cut or splice factory wiring if you use Polaris 2411686 winch switch extension. Make splice to contactor at end of this part. This keeps all original wiring intact.
stave7119 likes this.
Sprotsman is online now
Local Dealer Claims... autosport7 ATV General Discussion 17 04-12-2018 02:56 PM
Shock interchange TDMax Polaris XP 7 07-13-2016 05:21 PM
