250 trail boss carb upgrade - Polaris ATV Forum
post #1 of 7 (permalink) Old 04-28-2019, 01:43 PM Thread Starter
Mbal's Avatar
Will a vm 34mm mikuni fit the stock vm30mm carb adapter on a 93 250 trail boss. I've read that it makes a good performance upgrade.
Mbal is offline
post #2 of 7 (permalink) Old 04-28-2019, 05:12 PM
stave7119's Avatar
Yes, I think it will fit. If not, then the port size on the cylinder is about the same for all the small singles so get an adapter for 325 engine. But I don't think just changing the carb will help performance. You will need to do porting and polishing along with exhaust to match and probably fiddle with the jetting to get it to run right. Don't get me wrong, there are a lot of things you can do to get more performance from your 250. But you have to address the whole system not just one part. An engine is just a big air pump. So if you increase the size of the inlet without doing something to get the air through and back out you won't gain anything.
Hers: 2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. QSC Clutch Kit, Hand Warmers
2001 Magnum 325 Warn winch and Moose 60" plow
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #3 of 7 (permalink) Old 04-28-2019, 05:26 PM Thread Starter
Mbal's Avatar
Ok,I've bought a DG pipe and new crank seals ,new piston ,rings ,bored so it should be in good shape ,I was wanting to know if the 34 carb would fit in the 30 adapter.
Mbal is offline
post #4 of 7 (permalink) Old 04-29-2019, 06:44 AM
According to the Mikuni manual - both carbs have a 40mm spigot - both are 93mm long - both are 137mm tall - both are 83mm wide but, the bell for the air filter connection is 59mm on the VM30 and 58mm on the VM34
Yes, the 34 will fit the holder on the engine
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #5 of 7 (permalink) Old 04-29-2019, 10:20 AM
stave7119's Avatar
Sounds like you are on the way then! Let us know how it goes please. I have a 250 Xplorer and my son in law has a 250 Trail Boss
post #6 of 7 (permalink) Old 05-01-2019, 05:46 AM Thread Starter
Mbal's Avatar
Ok,thanks for the info ,I'll post the results when I get this thing running and jetted.
Mbal is offline
post #7 of 7 (permalink) Old 05-01-2019, 09:46 AM
Kingkat4's Avatar
I don't want to discourage you, however. Unless you are going to put a lot of time and a few bucks in for little return I would rebuild the old carb. I would rather ride than tune. let us know. Have fun
If I'm wrong tell me so
Kingkat4 is offline
1987 Trailboss es/r 250CC starter shot Rufusjr Polaris Trail Boss 2 04-28-2019 01:53 PM
1995 425 Magnum zflowers2852 ATV Repair and Maintenance 5 09-24-2018 09:15 AM
Flywheel nut 3083905 latebird ATV Repair and Maintenance 0 08-14-2018 02:34 PM
Compatibility matt1932 Polaris Scrambler 1 07-11-2018 08:49 AM
wheel stud replacement dbweathe ATV Repair and Maintenance 3 01-24-2018 11:01 AM
