Exhaust Insulation - Page 2 - Polaris ATV Forum
post #11 of 20 (permalink) Old 07-27-2014, 09:15 AM
scobar's Avatar
The material is blasted so as long as there are no thin spots that would blow through you should be fine.
I'll check those.
2009 Sportsman 500 EFI - 14" ITP SS212 with Kenda Bounty Hunters - EPI WE436258 clutch - ProMark 3000 lb XTR winch - ODI Rogue Lock-On Grips - 3 light mod - Ceramic coated exhaust - Ported TB and Manifold - LNR box - LNR Windshield - 4300k HIDs w/ projectors
2008 F-150 XLT 4X4 [email protected] SCAB Build Thread
2004 Saturn Ion Redline
scobar is offline
post #12 of 20 (permalink) Old 07-28-2014, 09:31 AM
SMOKEEATERFF's Avatar
I'm interested as well. Did you also coat the muffler? I know the plastic fender over the muffler gets pretty damn hot. Its very uncomfortable to my wife when she rides.
SMOKEEATERFF is offline
post #13 of 20 (permalink) Old 07-28-2014, 09:42 AM
scobar's Avatar
Everything was coated. Still trying to get a price.
scobar is offline
post #14 of 20 (permalink) Old 07-28-2014, 10:16 AM
scobar's Avatar
Ballpark $200-$250.
scobar is offline
post #15 of 20 (permalink) Old 07-28-2014, 11:19 AM
kemblkr's Avatar
Originally Posted by scobar View Post
LOL, sure
It is actually on my list to find a brain bucket before I hit any trails. Problem is finding one eye glass friendly
The AFX FX-39 is the best helmet and is eyeglass friendly. Its a dual sport so the windshield flips up and down so you don't need goggles.
Kevin (kemblkr)
2010 Sportsman 850 XP (Dark Green)
Koplin Overfenders
Polaris Front and Rear Bumpers
Polaris Winch
BlackWater Evolutions on 14's
Polaris Front and Rear Lock and Ride Cargo
Custom Bags on Cargo
Ricochet Ultimate Skid Plates
(Orange Anodized A-Arms)
Polaris Hand Guards
2- 1 Gallon Rotopax's in front storage
New addition: 2005 Honda VTX 1300R
kemblkr is offline
post #16 of 20 (permalink) Old 07-28-2014, 12:24 PM
bp405's Avatar
Thanx for following up so quickly sco. My plan around the thanksgiving to Christmas holiday is to do some clutch maintenance and universals on my prop shaft so when I have the bike down I could pull the exhaust and send it out. Thanx again.
Oh one more ?, like I was saying the exhaust has baked on mud so to what degree would I need to clean it or do I just pull it off and send it out?
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
2020 Outlander® 1000R XXC
bp405 is online now
post #17 of 20 (permalink) Old 07-28-2014, 01:02 PM
kemblkr's Avatar
how much room do you have between the exhaust (the part that is causing the heat issue) and the frame or plastics on the ATV? If you have a bit of room then I would suggest wrapping the exaust with a thermal blanket / paper then surround the blanket with thermal tape to secure.
The thermal blanket or paper (about 1/8" thick) is good up to like 2200 degrees so that should give you the protection against the heat transfer. Morgan PLC / Thermal Ceramics makes this product. Another option might be welders blanket as a base surrounded by thermal tape. Just reflective heat tape won't make that big of difference.
I'm suprised that a ceramic coating will make the exhaust cooler as ceramics transfer heat quite well but those that have had it done should know. My experience with ceramic coatings just keep the exhaust from rusting and make it look nice.
Kevin (kemblkr)
Koplin Overfenders
Polaris Winch
Polaris Hand Guards
kemblkr is offline
post #18 of 20 (permalink) Old 07-28-2014, 03:25 PM
scobar's Avatar
Knock off heavy debris, you'll have to send it or bring it to me. Ceramics can spread the heat out , and keep it in. Check out the wild cat, no heat shields, looks nice. Rzr heat shields, looks like poo.
scobar is offline
post #19 of 20 (permalink) Old 07-28-2014, 03:39 PM
bp405's Avatar
With my half an engineering degree and one thermodynamics class I was thinking the ceramic coating would dissipate the heat in an more even manor. Basically not collect in that one 180 deg bend.
Thanks for the heads up kemblkr.
Sco as I think of the coating (will do but haven't done my homework on it) how will it hold up to getting submerged in an ice cold Creek crossing in the dead of winter? Basically I'm just wondering what down side it may have.
The heat on my bike is there it isn't a major issue. A lot of guys are wrapping their exhausts. I would like to try something more permanent and different.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
2019 Aluma® A8818
bp405 is online now
post #20 of 20 (permalink) Old 07-28-2014, 03:47 PM
scobar's Avatar
I've got similar materials on the headers in my f150. They see 1200-1300ish egts without issue. Truck is driven year round through puddles snow drifts, and even the ditch. We have yet to have any reports of coating fractures or porosity.
The first coat in the exhaust above and on my headers is a barrier coating. The silver ceramic is very rich in aluminum which is where the chrome like appearance comes from. Some ceramics are also used for abrasion resistance, so not just heat.
scobar is offline
Exhaust seal replacement to exhaust wrap KICKER431 ATV Repair and Maintenance 44 05-09-2014 10:37 AM
850 exhaust Fullthrottle01 Polaris XP 5 08-01-2013 12:43 PM
850XP stock exhaust vs. Big Gun exhaust. Apache323 Polaris XP 12 08-01-2013 03:45 AM
cracking stock exhaust & aftermarket exhaust question yasam Polaris Scrambler XP 6 04-20-2013 06:20 AM
should i replace stock exhaust with performance exhaust? ifightfire ATV Performance Modifications 6 08-20-2012 01:04 PM
