550 qsc clutch kit ? - Polaris ATV Forum
post #1 of 6 (permalink) Old 07-20-2014, 01:04 PM Thread Starter
shed's Avatar
I'm running 27 " swamplites what shim should I run in the primary for best throttle responce low end I have both thick and thin in right now the low end is ok the midrange is great any info would be great thanks
shed is offline
post #2 of 6 (permalink) Old 07-20-2014, 01:39 PM
RVS Performance's Avatar
The 550 doesn't make much power under 2500 Rpm. Without bumping it even higher you are getting about all you can out of it now.
RVS Performance is offline
post #3 of 6 (permalink) Old 07-21-2014, 03:13 AM
LS6rally's Avatar
Can you add more shims to compensate? or would you just want a stronger spring?
2013 Sportsman 850XP H.O. EPS Touring - Blue Fire
Polaris 2500lb Winch W/ Syn Rope & Auto Stop, Heated Hand Grips, Heated Throttle Kit, Handguards, Mirrors, Storage Boxes - LED Headlights, ATV-Guru Cobra Front Bumper, K&N, NGK Plugs, Ricochet A Arm Guards, Ricochet Floor Board Guards, 60" American Eagle Plow, Worklight Mod, GoPro Hero 3, Polaris LED Headlight Upgrade, Custom Reg Decal Plate.
LS6rally is offline
post #4 of 6 (permalink) Old 07-21-2014, 05:30 AM
Would have to go to a stiffer start spring. Any more shims and you risk it coming out of the pocket, and it could bind up the spring on full shiftout too. Going higher will make it very difficult to maneuver at slow speeds and make take offs very harsh.
post #5 of 6 (permalink) Old 08-03-2014, 06:39 AM Thread Starter
shed's Avatar
Thanks for the info guys I didn't even think about break in time on a new belt that was the problem kit works great !
shed is offline
post #6 of 6 (permalink) Old 08-03-2014, 07:03 PM
Glad you got it figured out. Enjoy!
WTS: EPI clutch kit, 04 brush guard, and driven clutch assembly Redneckbmxer24 ATV Parts for Sale 8 06-11-2012 02:28 PM
Clutch or Clutch spring upgrade help!!! eazytony27 Polaris Scrambler 3 04-11-2012 09:55 PM
93 350L Drive Clutch and Driven Clutch Removal dpherll ATV General Discussion 1 11-24-2011 06:05 AM
having clutch problems wonder if its due to big tires or clutch wear HELP johnnypolaris500ho ATV Wheels & Tires 8 04-03-2011 07:17 PM
Primary clutch squeak after installing clutch kit x omerta x Polaris Sportsman 20 08-10-2010 01:46 PM
