2002 Polaris Sportsman 700 Clamps? - Polaris ATV Forum
post #1 of 3 (permalink) Old 01-14-2017, 10:05 AM Thread Starter
hwatkins's Avatar
There is a tee joint in the cooling system that requires 3 clamps on my 2002 Polaris 700, the part numbers are 7081047 (qty 2) and 7080826 (qty 1). The 7081047 clamp is not available anymore it looks like, is there a way to determine the size and what a good replacement would be?
The guy that had it before me replaced these with screw clamps, but they loosen up and allow coolant to leak.
hwatkins is offline
post #2 of 3 (permalink) Old 01-14-2017, 10:11 AM
bp405's Avatar
Just buy new screw clamps. I typically toss those OEM clamps in a box on the shelf and replace them with screw/hose clamps.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is online now
post #3 of 3 (permalink) Old 01-14-2017, 11:06 AM
Go to the auto parts or hardware and get some GOOD clamps (preferably stainless). The el cheapos are very flimsy at best and strip easily.
polman500 is online now
ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) FOR SALE KLCFLC Polaris Sportsman 2 02-18-2019 05:57 PM
3280431 ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) KLCFLC ATV New Members 1 09-18-2017 07:52 PM
2002 Polaris Sportsman 700 Winch Installation ssand746 Polaris Sportsman 2 09-10-2016 03:50 PM
Sportsman 700 Crankshaft Brawndo ATV Parts Wanted 2 06-07-2016 05:18 PM
