2001 Sportsman 700 Twin. No start - Polaris ATV Forum
post #1 of 14 (permalink) Old 02-01-2017, 05:56 AM Thread Starter
Streetglide's Avatar
I will be the first to admit that I dont know much about ATVs. I am working on my bosses atv and it will crank but will not start. It cranks but no spark. I found that the wires on the ststor were melted off so replaced stator. Still no start. Since then we have replaced regulater and ignition coil module. Still nothing. We checked the kill switch and found corrosion at the plug in. Replaced switch this morning. Still no start. Found it will start if I disconnect the black wire from kill switch to coil. As I dont have any manuals to look at I am totally lost. Can someone please point me in a direction to look?. Thank you in advance.
Streetglide is offline
post #2 of 14 (permalink) Old 02-01-2017, 08:38 AM
Old509cc's Avatar
Take a look at your ETC contacts in the throttle housing, if they are closed it will also cause no spark. While I'm not familiar with these early year twins, I do know there are ignition kits both OEM and aftermarket since the originals were not the best design. Has one of these kits been installed?
My ride
1999 Sportsman 509
Rebuilt. R2C air filter. BST40. QSC clutch kit in a QSC primary. Block & tank heaters.
Steel grease-able rod ends. HPD steering bushing. Custom hub vents.
Custom prop shaft lock collar. Rhino cv front axles. Borla 14" Pro XS muffler.
25" Sedona ripsaws on 12" Badlands. 2" level. Oury grips over hand-warmers.
Backup light. LED low beams. HID 35W high beam. Rev override switch delete.
Cooling fan light. Alba water temp, VDO volt, oil temp & pressure gauges.
Dad's
2014 Sportsman 570 EPS
2500 winch. Hand warmers. L&R windshield. L&R rear box. 60" Glacier. 26" HTRs.
Brothers'
2006 Sportsman 500 HO
2500 winch. 24" box. Prop shaft lock collar. LED low beams.
2014 RZR S 800
Superwinch Tera 3500. Roof, custom mounts. Pawltector parking brake.
F&R bumpers. Custom fire extinguisher mount. Rear diff pinion nut Torqued.
Faithful friends no longer with us
2004.5 Sportsman 500 HO.
2007 Rincon 680
Old509cc is offline
post #3 of 14 (permalink) Old 02-01-2017, 09:42 AM
stave7119's Avatar
I don't have a book for the 700 handy so I can't look at wiring diagrams. I would imagine it is the same as the other '01 machines though.
On my Magnums, if you can start it with that black wire removed and the kill switch is good, then the problem is probably the rev limiter. On the magnums, it is a separate part however they do not come with a speedo either. When I put a speedometer kit on one of mine, it replaced that with the same function in the speedometer itself. I think my 600 book covers the 700 too. I will look when I go out to the shop.
Edit: My book does not show a 2001 700. It starts at 2002, but there is no separate rev limiter. Everything goes into the speedometer
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #4 of 14 (permalink) Old 02-01-2017, 10:04 AM Thread Starter
Im sorry guys. I entered the wrong year. It is a 2002 caburated.
post #5 of 14 (permalink) Old 02-01-2017, 04:19 PM
stave7119's Avatar
No sweat about the year.....If you don't already have one, you will want a repair manual with the wiring diagrams in it. Mine is a Clymer that covers the 600, 700 and 800 Sportman models. You are gonna have to start tracing down wires. If everything in the speedo works then it could just be a shorted wire in there somewhere.
post #6 of 14 (permalink) Old 02-01-2017, 04:55 PM
If it starts with the black wire off the kill switch it sounds like you may just need a switch.
polman500 is offline
post #7 of 14 (permalink) Old 02-02-2017, 07:49 AM
rmstator's Avatar
Send a message via Skype™ to rmstator
The key is that it will start with the black wire disconnected at the CDI/Coil unit. That is the kill switch wire. If you've already replaced the kill switch, then the problem is a short to ground in that black wire somewhere along the harness before it reaches the CDI/Coil. My guess is if you trace it carefully, you'll find a spot where the insulation is worn off and you have a short to the frame in that wire somewhere. Start there and totally rule out that black wire grounding before looking at anything else! Let me know what you find. The Sporty 600/700's are notorious for stator source coil failures and failures of the combined CDI/Coil unit, but that doesn't seem to be the case here.
rmstator is offline
post #8 of 14 (permalink) Old 04-02-2017, 06:51 PM
greg7764's Avatar
2003 sportsman same issue.
Having the same issue with my 03 700. New CDI (aftermarket) and new kill switch (Polaris). When Ohmed, Black wire to kill switch will show ground until you turn the key on, but if you start it with the ground wire disconnected, it will not kill the motor when you shut the key off. I need a wiring Schematic. . .
greg7764 is offline
post #9 of 14 (permalink) Old 04-03-2017, 07:48 AM
rmstator's Avatar
Strange...Here is a wiring diagram for a 2002 Sportsman 700, pretty much the same.
rmstator is offline
post #10 of 14 (permalink) Old 04-08-2017, 02:31 PM
greg7764's Avatar
voltage at ground wire?
Here is what I figured out. kill switch (KS) in run position, key off, kill wire is grounded. KS in run, key on, have battery voltage. According to the schematic, at the key switch, do you see the connection being made between c-d, and e-f or c-f, d-e?
greg7764 is offline
ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) FOR SALE KLCFLC Polaris Sportsman 2 02-18-2019 05:57 PM
3280431 ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) KLCFLC ATV New Members 1 09-18-2017 07:52 PM
Sportsman 700 Crankshaft Brawndo ATV Parts Wanted 2 06-07-2016 05:18 PM
