'01 Sportsman rear axle removal - Page 3 - Polaris ATV Forum
 7Likes
post #21 of 30 (permalink) Old 06-15-2017, 02:47 PM
thumper1500's Avatar
LOL - yeah, a BFH is always your friend in these situations!
2015 Sportsman XP 1000 Touring
Bronze Mist
QSC Clutch Kit
Ricochet Ultimate Armor Kit
HighLifter 2" lift kit
Kenda Bearclaw HTR 28" tires
Cecco frame braces
Cecco billet front pinion cover
Guru silver bumpers
12" LED lightbar
2" hitch w/bottle opener
Mid smoke windshield
Tatou 4s tracks for the snow
Synth winch line and Hawse fairlead
LED headlights
Wired for electric helmets
thumper1500 is offline
post #22 of 30 (permalink) Old 06-18-2017, 11:44 AM Thread Starter
Muggzy's Avatar
The BFH isn't cutting it either.. I've got the quad chained to the lolly column so it won't move, enough chain for a good swing and all the excess chain wrapped around the 10lb sledge. Guessing that's about 12lbs in total. I left the screw drivers in thinking that if it moves at all, the screw drivers would drop out. Didn't budge at all.
Sent from my SM-G920V using Tapatalk
'01 Polaris Sportsman 500 HO project (needs a 'lil TLC. OK, OK, a LOT of TLC)
My first 4WD ATV!
1" wheel spacers, 25" STI Black Diamond Tires, Front and rear storage with seat.
My other ride is a 2-stroke sport quad.
Muggzy is offline
post #23 of 30 (permalink) Old 06-18-2017, 01:10 PM
Tmtbob's Avatar
Chain the wheel to the post so you can get a direct line of force. Then swing that bfh like hell.
Tmtbob is offline
post #24 of 30 (permalink) Old 06-21-2017, 06:55 PM Thread Starter
Muggzy's Avatar
If I wasn't worried about pulling the column out from under my house, I'd put a cumalong on the chain instead of that hammer and anchor the other end of the cumalong to my car.
My first 4WD ATV!
Muggzy is offline
post #25 of 30 (permalink) Old 06-22-2017, 04:37 AM
Bshuk57's Avatar
At this point I'd be looking into the cost of a new transaxle. This thing has been fighting you for so long I don't think I'd dare putting new axles into that housing even if you did get them out
Bshuk57 is offline
post #26 of 30 (permalink) Old 06-22-2017, 09:50 AM
Dang Mugzy that baby must be stuck good!
Go right around the cup whacking the piss out of it to try and break the rust loose.
There used to be a utube video I saw sometime back that a guy in your predicament actually laid the wheeler on its side and tied to the rafters with a come along. Jacked it up a little to put pressure on it. Whacked the cup and it popped out.
polman500 is online now
post #27 of 30 (permalink) Old 07-05-2017, 03:10 PM Thread Starter
Muggzy's Avatar
I finally caved and took it to a friend's shop. I'd rather pay him 300-500 to pull the both of them and re-install everything.
My first 4WD ATV!
Muggzy is offline
post #28 of 30 (permalink) Old 07-05-2017, 04:00 PM
sportsmandan's Avatar
he shouldn't charge u more than 1 hour labour,
$80 $90 max full rate per/hour to unstuck them.
2016 Scrambler 1000 xp
GSE single slip on muffler
Direction2 flares
2016 Sportsman 570 non ebs
Direction2 flares
ITP XTR radials
sportsmandan is offline
post #29 of 30 (permalink) Old 07-05-2017, 06:56 PM
Yeah, $100 should be a big price just to get them out for you.
post #30 of 30 (permalink) Old 07-06-2017, 04:19 AM Thread Starter
Muggzy's Avatar
I'd agree if all he was doing was pulling those axles AND I hadn't already tried pulling it out with a cumalong and airhammer. It's going to take him more than an hour.
He'll also be putting everything back together including a complete set of axles and bushings on both sides. So I'm OK with that. And while he is a buddy, business is business.
carch4 likes this.
My first 4WD ATV!
Muggzy is offline
Service manuals cookies ATV Repair and Maintenance 1100 08-12-2019 09:38 AM
3280431 ASM-CLUSTER,110MM,W/FUEL (Speedo Cluster) KLCFLC ATV New Members 1 09-18-2017 07:52 PM
