Xplorer 300 Stopped Running - Page 2 - Polaris ATV Forum
post #11 of 15 (permalink) Old 08-21-2015, 06:31 PM
jtka9ljw's Avatar
Originally Posted by aknawful View Post
Originally Posted by jtka9ljw View Post
Originally Posted by PolarisSucks View Post
I own a 1996 Polaris Xplorer 300 (Got it for dirt cheap) and I had to replace the carb. The atv has very low hours I knew the original owner and he drove it once or twice a year. Once I replaced the carb the atv ran fine for some time. I returned home from a trip overseas to find out someone rode the atv and it sounded like it ran out of fuel and stopped running. I checked the atv when I returned home and cannot get it to start up.
I pulled the head to check the piston, it looked fine, I replaced the head gasket. The engine fires when turning over. I replaced the spark plug. I also spray starting fluid with the fuel switch off to ensure I will not flood the engine. The engine still does not fire. I pulled the cover to see if the pin has been sheared on the flywheel and it has not sheared. I replaced the cdi box although I was pretty sure that wasn't the problem.
A 2 stroke engine is not that complicated, what am I missing? Does this model have a reed cage that I am unaware of? Could the timing be off even though the flywheel pin was not sheared? The engine feels like it has good compression.
Any suggestions would be appreiated, I am ready to scrap this POS even though it is basically brand new with original tires and all.
there is a tiny capacitor in the plug wire end and a small spring on the wire side pull the pointed piece that screws on the wire out with needle nose pliers and clean
you do know this thread is 4 years old?
no I didn't but there's bound to be others that have this problem
jtka9ljw is offline
post #12 of 15 (permalink) Old 08-21-2015, 07:16 PM
Markcuda's Avatar
Red face
This is way to funny.LOLOLOLOLLLOOOOLOOLOLOLOLOLOLO
Oh my Lord.
I wonder if the guy ever got her running?
Mine2015-850 Touring SP Sunset Red,Bought 5-16-15
Miles=2484
Hours=136.7
Billet gas cap
Sticker delete
Throttle assist
Tires balanced
Billet shift knob
Billet flag mount
Polaris twin mirrors
26 inch Kenda HTRs
Direction2 Overfenders
DXTrigger finger throttle
Polaris F/R brush guards
1-up touring rear cargo box
Polaris3"passenger foot risers
Polaris lock & ride small rear box
Polaris 1 inch drop receiver hitch
Zurich 4 year extended warranty
Amerex2.5pound HalotronI fire extinguisher
Wife's2015-850-SP Sunset Red,Bought 7-16-16
Billet gas cap
Sticker delete
Throttle assist
Tires balanced
Billet shift knob
Billet flag mount
Polaris 3500 winch
26 inch Kenda HTRs
2 inch drop receiver hitch
Lock & RideŽ Front Cargo Box
Zurich 2 year extended warranty
Lock & RideŽ Rear Cargo Box#2875176
Ansul Sentry2.5pound dry chemical fire extinguisher
Markcuda is offline
post #13 of 15 (permalink) Old 06-30-2016, 02:30 PM
ninja11zx's Avatar
This thread is old but im having same issues now with a 300. just stopped running last winter. now it wont start. has excellent spark, cleaned carb. i have read about it shearing a pin. going to check that now. can cover be removed in frame. one bolt is behind the brake. comp is 80 lbs with a good motorcycle gage not my finger. thanks for any imput.
ninja11zx is offline
post #14 of 15 (permalink) Old 06-30-2016, 03:32 PM
twostarrz's Avatar
80 psi is too low. For sure needs piston/rings. My bet would be that piston skirt came apart.
Mine - 2013 polaris sportsman 800. 28x9x12 and 28x11x12 ITP mega mayhems on 12x7 ITP black steel wagon wheels, 4500# venom winch, rear tool box.
Hers - 2008 Yamaha wolverine 450. 26x12x12 super grip super lites rear, 26x9x12 super grip super lites front, 1 1/2" spacers all the way around, pro mark 3000# winch on custom mount, HMF pipe, K&N air filter, jet kit, custom rear rack with seat/toolbox and 5 gallon gas can mount.
Daughter - 1999 polaris scrambler 500 4x4. 22x12x10 bear claws rear, 23x7x10 bear claws front, reinforced rear swing arm (long story), 4" lift kit in rear, 3000# promark winch on custom by me front bumper, rear cargo box.
Sons - 2000 polaris scrambler 400 4x4. 22x12x10 bear claws rear, 23x7x10 bear claws front, 4" lift kit in rear, rear cargo box
Sold:
2004 Yamaha warrior 350
1999 Yamaha blaster 240 big bore
1995 kawasasaki Mojave 250
2001 Polaris sportsman 90
2008 kolpin 90
1985 Suzuki lt250R quadracer
twostarrz is offline
post #15 of 15 (permalink) Old 07-02-2016, 11:34 AM
ninja11zx's Avatar
Rechecked comp. was down to 60 psi so new piston and rings on order.
Tags
2 stroke, reed valve, won't run, xplorer 300
Need Help 96 Magnum AWD stopped working johnpeter ATV Repair and Maintenance 2 02-02-2014 02:35 PM
05 Sportsman Stopped ridgeline ATV Repair and Maintenance 15 03-31-2011 05:08 PM
Just bought a xplorer 400 trying to get it running mcurcio1989 ATV Repair and Maintenance 21 02-16-2011 09:16 PM
1997 polaris xplorer 300 running problems, help jason6586 ATV Repair and Maintenance 1 09-22-2010 08:38 AM
Xplorer wont stay running after 15minutes cornerstonepits ATV Repair and Maintenance 1 07-12-2009 05:08 AM
