2004 700 rear axle - Polaris ATV Forum
post #1 of 4 (permalink) Old 10-26-2017, 04:21 PM Thread Starter
ttori7046's Avatar
2004 700 rear axle
I have a 2004 Polaris sportsman. The rear right axle broke near the differential. I purchased an aftermarket axle and after installation the axle slipped out of the rear diff. I re installed it 5 times and the same thing kept happening. I then purchased a Polaris used axle and it stayed in the first install. Now that axle broke by the diff. I ordered a new HD aftermarket axle and I have the same problem. The axle keeps slipping out of the diff. Do I need to order a new Polaris brand axle? Any suggestions?
ttori7046 is offline
post #2 of 4 (permalink) Old 10-28-2017, 09:15 PM
stave7119's Avatar
Do the aftermarket axles have the retaining clip on the end of the splined part that goes into the differential? The axle should snap into the diff and you should be able to tug on it without it coming out easily. Usually takes a good bit of effort to get them out. Is your machine lifted? That could make a difference too.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #3 of 4 (permalink) Old 10-29-2017, 03:29 AM
bp405's Avatar
Are the axels the same size? Length??
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #4 of 4 (permalink) Old 11-05-2017, 11:16 PM
sarabmiller's Avatar
^^ all of this. And you're getting everything out the right way and putting the new parts in correctly? (https://www.americancvstore.com/technical-help for a basic primer)
sarabmiller is offline
2004 Sportsman Axle Issues shawbran Polaris Sportsman 8 03-22-2016 08:28 AM
