07 Sportsman 500 DLX CV Boot Replacement question - Polaris ATV Forum
post #1 of 3 (permalink) Old 02-06-2018, 02:24 PM Thread Starter
Idahonativeguy's Avatar
I have a 2007 Sportsman 500 dlx. I am trying to replace the rear CV boot which requires pulling the axle out. All I have seen on You Tube shows a Clamp (snap ring) that you have to remove for it to pull out. Mine does not have this clamp? How do you get it out of there and back in? I appreciate any answers.
Idahonativeguy is offline
post #2 of 3 (permalink) Old 02-06-2018, 05:11 PM
Some cheap aftermarket drive shafts are crimped instead of having a snap ring. Boot tears and you replace the shaft
latebird is offline
post #3 of 3 (permalink) Old 02-06-2018, 06:57 PM
If you're talking about getting the axle out, you just jerk straight out on it once you get the hub and bearing carrier and stuff out of the way. There is a spring ring (#6) on the end of the shaft that holds it in the differential. A retaining ring holes the CV on the shaft (#7) and the boot is held on with clamps (#'s 4 and 2). They are ALL made the same general way with some slight variations.
Not sure what you're talking about a "Clamp (snap ring)"??
polman500 is offline
