570 starting issue - Polaris ATV Forum
post #1 of 7 (permalink) Old 02-25-2018, 01:03 PM Thread Starter
llamaguy93's Avatar
570 starting issue
Hey everyone. My 570 sometimes will stop turning over when it builds up compression and I have to "jog" the key 5 or 6 times to make it finish cranking over. Original battery(2015), topped off with distilled water but still does it occasionally. I'm thinking of upgrading the battery to something with more CCA. here's a video from YouTube of what is happening. Let me know what you guys think
llamaguy93 is offline
post #2 of 7 (permalink) Old 02-25-2018, 01:13 PM
Hmm...Could be battery or starter. You can load test the battery at most auto parts stores.
Have you checked charging?
Should have around 14.5 at 2500 RPM.
You can test starter by using booster cables to put 12v directly to the terminal.
If all is good with battery and starter, you may have to look at the decompression assembly.
polman500 is offline
post #3 of 7 (permalink) Old 02-25-2018, 02:04 PM
tony357's Avatar
That's going to be battery, make sure the battery cable ends are clean. upgrade to an AGM battery.
2016 sportsman 570 Orange Burst
3500 winch
KFI winch mount
Dice Gear Shifter Knob
LED ground graphics
ACERIB X PRO Handguards
AGM battery upgrade
2014 sportsman 400 HO blue fire
polaris hand guards
polaris mid windshield black
polaris rear cargo box
KFI winch mount
Badlands 2500 winch
2001 Honda 400EX
2003 Yamaha blaster
2001 Yamaha bear tracker
1988 yamaha YFM 225 lost in sandy
tony357 is offline
post #4 of 7 (permalink) Old 02-26-2018, 07:01 AM
Try holding the throttle wide open, then cranking and see if that makes it crank over better - if not, new battery
latebird is offline
post #5 of 7 (permalink) Old 02-26-2018, 09:18 AM
DOAinNY's Avatar
Believe it or not, the polaris tech at my dealer tells me that this is "a 570 thing." When the engine stops in the compression stroke near top dead center, the battery doesn't have enough amps to muscle through the compression.
I went and bought a new sealed battery (better CCA, too) for my new wheeler with only 200 something miles on it, and when I got to the shop the old battery tested fine and when I expressed my sincere disbelief at the entire thing, the tech pulled out that gemstone for me.
I told him, and anyone at Polaris that cares to listen that hearing that about my $10K sportsman was not very comforting.
Fast forward to a couple weeks ago, and it happened to me again while out in the woods, a long walk to the nearest road. I bumped it a half dozen times until it finally fired and boy was I worried. Has been fine since, though. I rode it the past couple weekends with no issue.
2017 Sportsman 570 SP Hunter Edition
Pursuit Camo
DOAinNY is offline
post #6 of 7 (permalink) Old 02-26-2018, 09:19 AM
DOAinNY's Avatar
Even with electronic fuel injection? Is this something that the computer reads?
Pursuit Camo
DOAinNY is offline
post #7 of 7 (permalink) Old 02-26-2018, 02:11 PM
tony357's Avatar
computer will not read that, not sure if they have crank position failure code but it is possible for that to come up it may sense to quick of count if it pops backwards.
3500 winch
KFI winch mount
LED ground graphics
AGM battery upgrade
polaris hand guards
KFI winch mount
Badlands 2500 winch
2001 Honda 400EX
2003 Yamaha blaster
tony357 is offline
Ignition switch 570 sportsman Fivespeed ATV New Members 4 12-15-2017 07:03 AM
2016 Polaris 570 Hard Starting and Stalling Issue. EricTA Polaris Sportsman 570 11 06-29-2017 06:04 PM
polaris 570 2015 exhaut heating gab570 Polaris Sportsman 2 05-19-2017 10:58 AM
Polaris Sportsman 570 Touring eps intermittent Starting issue Sandtrap9072 Polaris Sportsman 2 05-19-2016 12:55 PM
