Does anyone know if the rear hubs are interchangeable from a sportsman to an ATP? The part number for the ATP hub is discontinued (5133360) so I am not able to order them.
I typed in that number on ebay and it shows front hub for a sportsman 400 and 700. Take a look see. Are the splines all chewed up? They may have updated that number to an all steel hub.
Assemblies where 5133360 is used
2002 SPORTSMAN 700 (A02CH68AA/AB/AC/CA/CB) - Front Wheel
2003 500 MAGNUM 4X4 HDS (A03CD50FB) - Front Wheel
2003 500 MAGNUM 4X4 HDS (A03CD50FB) - Swing Arm/Rear/Gearcase Mounting
2003 MAGNUM 330 2X4 (A03CB32AA) - Swing Arm/Rear/Gearcase Mounting /Fc
2003 MAGNUM 330 4X4 (A03CD32AA/AB/AC/FB) - Front Wheel
2003 MAGNUM 330 4X4 (A03CD32AA/AB/AC/FB) - Swing Arm/Rear Gearcase Mounting
2003 SPORTSMAN 600 (A03CH59AA) - Front Wheel /Af/Ag
2003 SPORTSMAN 700 (A03CH68AA/AC/AF/AH/AL) - Front Wheel
2004 A04CH42AQ SPORTSMAN 400 (A04CH42AQ/AR/AS/AT/AV) - Front Wheel
2004 A04CH50AQ SPORTSMAN 500 (A04CH50AO/AQ/AR/AS/AT/AV/AW/AX) - Front Wheel
2004 A04CH59AF SPORTSMAN 600 (A04CH59AF/AH/AJ/AT/AV) - Front Wheel
2004 A04CH59AK SPORTSMAN 600 (A04CH59AK/AL/AN/AQ/AW) - Front Wheel
2004 A04CH68AC SPORTSMAN 700 (A04CH68AC/AF/AH/AJ/AT/AV) - Front Wheel
2004 A04CH68AK SPORTSMAN 700 (A04CH68AK/AL/AN/AO) - Front Wheel
2004 A04CH68AU/CU SPORTSMAN 700 (A04CH68AP/AQ/AU/CU) - Front Wheel
2004 A04JD50AA ATP 500 4X4 (A04JD50AA/AB/CA) - Rear Wheel Drive
2004 A04JD50AA ATP 500 4X4 (A04JD50AA/AB/CA) - Front Wheel
2004 ATP 330 4X4 (A04JD32AA) - Rear Wheel Drive
2004 ATP 330 4X4 (A04JD32AA) - Front Wheel
2004 MAGNUM 330 2X4 (A04CB32AA) - Swing Arm/Rear/Gearcase Mounting /Fc
2004 MAGNUM 330 4X4 (A04CD32AA) - Front Wheel /Ab/Ac/Fb
2004 MAGNUM 330 4X4 (A04CD32AA) - Swing Arm/Rear/Gearcase Mounting /Ab/Ac/Fb
2005 ATP 330 4X4 (A05JD32AA) - Rear Wheel Drive
2005 ATP 330 4X4 QUAD (A05JD32EA) - Rear Wheel Drive
2005 ATP 500 4X4 (A05JD50AA) - Rear Wheel Drive /Ab/Ac
113.4K members
