1999 500 Scrambler No Spark Replaced CDI, Coil - Polaris ATV Forum
post #1 of 8 (permalink) Old 06-21-2011, 02:23 PM Thread Starter
kstafford's Avatar
Hi there, I have a 1999 Polaris 500 Scrambler that I can't get spark. I have replaced the coil, voltage regulator and the CDI. Is there anything other than the Stator that could cause it to not have spark. Can I test the Stator? Does it have a Rectifier? Thanks in advance for the help.
kstafford is offline
post #2 of 8 (permalink) Old 06-21-2011, 03:45 PM
Bruce! is offline
post #3 of 8 (permalink) Old 06-21-2011, 07:16 PM Thread Starter
kstafford's Avatar
Hey thanks Bruce! Looking forward to the expertise of the users on here to help out. I have worked on ATV's lots especially Polaris so I may be helpful too I hope.
post #4 of 8 (permalink) Old 07-09-2011, 09:08 AM Thread Starter
kstafford's Avatar
Apparently I'm not the only one stumped, Going to try to figure out how to test the stator today.
post #5 of 8 (permalink) Old 07-10-2011, 05:32 AM
lostmech's Avatar
You can get the service manual from the ATV Repair and Maintenance Section and it should say in the manual how to check the stator.
lostmech is offline
post #6 of 8 (permalink) Old 07-10-2011, 05:32 PM
chopperbill's Avatar
The stator itself is for the charging system. If you have replaced all the parts you said you have the problem may be the pickup (pulser)coil which triggers the spark on the flywheel where the stator is located. Personally I have never had to replace one so I dont know the percentages of them going bad. But to answer your question on the stator you need to find the ohm readings in the manual and test all the legs (wires,not sure of the colors) coming from the stator harness. None should show continuity to ground. Easy test is to take the mag cover off, remove flywheel (you will need a puller) and see (smell) if the stator is burnt. It probably take less time than you think it will.
chopperbill is offline
post #7 of 8 (permalink) Old 07-10-2011, 07:11 PM Thread Starter
kstafford's Avatar
Thanks for the advice, I finally got the time to just pull the stator off. I found that something had bounced around in there and hit the pickup and 1 of the 2 ignition bobbins is burnt out. New stator is on the way, hopefully that works.
post #8 of 8 (permalink) Old 07-19-2011, 09:09 PM Thread Starter
kstafford's Avatar
The stator fixed it, she's rippin' again, thanks again for the advice and the help received from other post as well, great info on this site if can handle sifting through the know-it-all smart ass posts.
1999 250 Trailblazer - No spark - HELP! 1999TRAILBLAZER Polaris Trail Blazer 10 04-21-2017 11:17 AM
1999 Scrambler 500 No spark Costjohj ATV Repair and Maintenance 2 06-21-2011 07:12 PM
2000 scrambler 400 exciter coil mtomsen ATV Repair and Maintenance 2 06-16-2011 10:46 AM
1999 Sportmans - No spark Doc25 ATV Repair and Maintenance 1 04-20-2010 08:40 AM
1999 250 Trailblazer - No spark 1999TRAILBLAZER ATV Repair and Maintenance 4 11-04-2009 12:10 PM
