1995 425 Magnum - Polaris ATV Forum
post #1 of 6 (permalink) Old 09-20-2018, 06:19 AM Thread Starter
zflowers2852's Avatar
1995 425 Magnum
Good morning, I’m new to the site and tried searching this issue with little luck...hopefully someone will be able to chime in and give me a little advice. I have a friend who has a 95 magnum 425...let me stop here to note that I just recently had to teach him how to generate an email...it goes without saying that searching these forums is a little above his level...recently he noticed he had bad bearings in his axle carrier and tried replacing them only to find the new bearings would just “fall in and out” (his words)...he noticed that the old bearings apparently have worn out the aluminum carrier housing...we have tried checking local, and even a couple national, polaris salvage yards...and talked to the dealers...no luck...we are now considering swapping in a different axle (he is a certified welder so moving mounts won’t be an issue) just looking for some thoughts or advice...thank you in advance
zflowers2852 is offline
post #2 of 6 (permalink) Old 09-20-2018, 08:59 AM
I found more than 70 listings for that part on Ebay - part number 5130663
The part was used on these models including 2x4, 4x4 and 6x6:
1988 TRAIL BOSS 250 (X888528) - Rear Wheel Drive Assembly
1988 TRAIL BOSS 250 (X888528) - Swing Arm Weldment & Rear Shock Assembly
1988 TRAIL BOSS 250 R/ES (W888528) - Rear Wheel Drive Assembly
1988 TRAIL BOSS 250 R/ES (W888528) - Swing Arm Weldment & Rear Shock Assembly
1989 BIG BOSS (W899627) - Rear Wheel Drive Assembly
1989 BIG BOSS 4X6 (W898627) - Middle Drive Assembly
1989 BIG BOSS 4X6 (W898627) - Rear Wheel Drive Assembly
1989 BIG BOSS 4X6 (X898627) - Rear Wheel Drive Assembly
1989 TRAIL BOSS (W898527) - Real Wheel Drive Assembly
1989 TRAIL BOSS (W898527) - Swing Arm Weldment & Rear Shock Assembly
1989 TRAIL BOSS 2X4 (W897527) - Rear Wheel Drive Assembly
1989 TRAIL BOSS 4X4 (W898127) - Rear Wheel Drive Assembly
1989 TRAIL BOSS 4X4 (W898127) - Swing Arm Weldment & Rear Shock Assembly
1990 BIG BOSS 4X6 (W908627) - Middle Drive Assembly
1990 BIG BOSS 4X6 (W908627) - Rear Wheel Drive Assembly
1990 TRAIL BLAZER (W907221) - Swing Arm Weldment & Rear Shock Assembly
1990 TRAIL BLAZER (W907221) - Rear Wheel Drive Assembly
1990 TRAIL BOSS 250 (W908527) - Rear Wheel Drive Assembly
1990 TRAIL BOSS 2X4 (W907527) - Swing Arm Weldment & Rear Shock Assembly
1990 TRAIL BOSS 2X4 (W907527) - Rear Wheel Drive Assembly
1990 TRAIL BOSS 350L 2X4 (W907539) - Swing Arm Weldment 350 2X4
1990 TRAIL BOSS 350L 2X4 (W907539) - Rear Wheel Drive Assembly 350 2X4
1990 TRAIL BOSS 350L 4X4 (W908139) - Rear Wheel Drive Assembly
1990 TRAIL BOSS 350L 4X4 (W908139) - Swing Arm Weldment & Rear Shock Assembly
1990 TRAIL BOSS 4X4 (W908127) - Swing Arm Weldment & Rear Shock Assembly
1990 TRAIL BOSS 4X4 (W908127) - Rear Wheel Drive Assembly
1991 BIG BOSS 4X6 (W918627) - Middle Drive Assembly Big Boss 4X6
1991 BIG BOSS 4X6 (W918627) - Swing Arm Weldment Big Boss 4X6 Updated 2 91 (4919801980027A)
1991 TRAIL BLAZER (W917221) - Swing Arm Weldment/Rear Shock Assembly Trail Blazer
1991 TRAIL BOSS 250 (W918527) - Rear Wheel Drive Assembly Trail Boss Update
1991 TRAIL BOSS 2X4 (W917527) - Rear Wheel Drive Assembly 250 2X4 Update
1991 TRAIL BOSS 350L 2X4 (W917539) - Rear Wheel Drive Assembly 350 2X4 Update
1991 TRAIL BOSS 350L 4X4 (W918139) - Rear Wheel Drive Assembly 350 4X4 Update
1991 TRAIL BOSS 350L 4X4 (W918139) - Swing Arm Wld./Rear Shock Asm. 350 4X4 Update
1991 TRAIL BOSS 4X4 (W918127) - Rear Wheel Drive Assembly 250 4X4 Update
1992 BIG BOSS 4X6 (W928627) - Rear Wheel Drive Assembly 250 4X6
1992 BIG BOSS 6X6 (W928727) - Rear Wheel Drive Assembly 250 6X6
1992 EURO BIG BOSS 6X6 (S928727) - Rear Wheel Drive Assembly 250 6X6 / W928727
1992 TRAIL BLAZER (W927221) - Rear Wheel Drive Assembly Trail Blazer
1992 TRAIL BOSS 250 (W928527) - Rear Wheel Drive Assembly Trail Boss
1992 TRAIL BOSS 2X4 (W927527) - Rear Wheel Drive Assembly 250 2X4
1992 TRAIL BOSS 350L 2X4 (W927539) - Rear Wheel Drive Assembly 350 2X4
1992 TRAIL BOSS 350L 2X4 (W927539) - Swing Arm Weldment 350 2X4
1992 TRAIL BOSS 4X4 (W928127) - Rear Wheel Drive Assembly 250 4X4
1993 250 2X4 (W937527) - Rear Wheel Drive Assembly
1993 250 4X4 (W938127) - Rear Wheel Drive 4X4 250
1993 250 6X6 (W938727) - Swing Arm/Guard Mounting 6X6 250
1993 350L 2X4 (W937539) - Rear Wheel Drive Assembly 2X4 350L
1993 350L 4X4 (W938139) - Rear Wheel Drive Assembly 4X4 350L
1993 350L 6X6 (W938739) - Swing Arm/Guard Mounting 6X6 350L
1993 EURO 350L 4X4 (S938139) - Rear Wheel Drive Assembly 4X4 350L W938139
1993 EURO 350L 6X6 (S938739) - Swing Arm/Guard Mounting 6X6 350L W938739
1993 SPORTSMAN 4X4 (W938039) - Rear Wheel Drive Assembly Sportsman 4X4
1993 TRAIL BLAZER (W937221) - Rear Wheel Drive Assembly Trail Blazer
1993 TRAIL BOSS (W938527) - Rear Wheel Drive Assembly Trail Boss
1994 300 2X4 (W947530) - Rear Wheel Drive Assembly 2X4 300
1994 300 4X4 (W948130) - Rear Wheel Drive Assembly 4X4 300
1994 300 6X6 (W948730) - Swing Arm/Guard Mounting 6X6 300
1994 400L 2X4 (W947540) - Rear Wheel Drive Assembly 2X4 400L
1994 400L 4X4 (W948140) - Rear Wheel Drive Assembly 4X4 400L
1994 400L 6X6 (W948740) - Middle Drive Assembly 6X6 400L
1994 400L 6X6 (W948740) - Swing Arm/Guard Mounting 6X6 400L
1994 NORWEGIAN 400L 4X4 (N948140) - Rear Wheel Drive Assembly Swedish 4X4 400L S948140
1994 NORWEGIAN 400L 6X6 (N948740) - Swing Arm/Guard Mounting 6X6 400L, Swedish S948740 & Norwegian
1994 SPORT 400L (W948540) - Rear Wheel Drive Assembly Sport 400L
1994 SWEDISH 400L 4X4 (S948140) - Rear Wheel Drive Assembly Swedish 4X4 400L
1994 SWEDISH 400L 6X6 (S948740) - Swing Arm/Guard Mounting 6X6 400L, Swedish & Norwegian N948740
1994 TRAIL BLAZER (W947221) - Rear Wheel Drive Assembly Trail Blazer
1994 TRAIL BOSS (W948527) - Rear Wheel Drive Assembly
1995 BIG BOSS 6X6 400L (W958740) - Swing Arm/Guard Mounting 6X6 400L U.S. , Swedish S958740 & Nor
1995 MAGNUM 4X4 (W958144) - Rear Wheel Drive Assembly
1995 NORWEGIAN MAGNUM 4X4 (N958144) - Rear Wheel Drive Assembly W958144
1995 SWEDISH MAGNUM 4X4 (S958144) - Rear Wheel Drive Assembly W958144
1995 TRAIL BLAZER (W957221) - Rear Wheel Drive Assembly Trail Blazer
1996 400L 6X6 (W968740) - Rear Wheel Drive 6X6 400L & 6X6 400L Norwegian N968740
1996 400L 6X6 (W968740) - Middle Drive 6X6 400L & 6X6 400L Norwegian N968740
1996 NORWEGIAN 400L 6X6 (N968740) - Middle Drive 6X6 400L W968740 & 6X6 400L Norwegian
1997 MAGNUM 6X6 (W97AE42A) - Rear Wheel Drive Magnum 6X6 & Swedish Magnum 6X6 S97ae42e
1999 BIG BOSS 500 6X6 (A99AE50AA) - Rear Wheel Drive A99ae50da
1999 INTL BIG BOSS 500 6X6 (A99AE50DA) - Rear Wheel Drive
latebird is offline
post #3 of 6 (permalink) Old 09-20-2018, 07:33 PM Thread Starter
Thank you for the very informative response...it definitely gives us a good direction to go
post #4 of 6 (permalink) Old 09-21-2018, 07:02 AM
Yeah, there's bunches of them on ebay. Just copy/paste the part number. I prefer to buy from Powersports Nation if possible since they stand behind all their parts 100%.
polman500 is online now
post #5 of 6 (permalink) Old 09-23-2018, 06:09 PM Thread Starter
I appreciate your input...I’ll look into powersports nation...a company that stands behind their products is going to ease one of our concerns...we are worried about how much life might be left on a used part from ebay (even if it’s in excellent condition)...I’m getting the impression that this was a common issue for the carrier...one of the polaris wrecking yards and the dealer both told us that it was very common...I’ll look into powersports nation...thanks
post #6 of 6 (permalink) Old 09-24-2018, 09:15 AM
Originally Posted by zflowers2852 View Post
I appreciate your input...Iíll look into powersports nation...a company that stands behind their products is going to ease one of our concerns...we are worried about how much life might be left on a used part from ebay (even if itís in excellent condition)...Iím getting the impression that this was a common issue for the carrier...one of the polaris wrecking yards and the dealer both told us that it was very common...Iíll look into powersports nation...thanks
I don't think that would be a very common issue unless you run it with the bearing out for so long that it seizes up making the bearing spin in the carrier...then its ruined!
1995 425 magnum camshaft Brad4x4 Polaris Magnum 1 02-20-2018 08:14 AM
95 xplorer transmission case Posdeer ATV General Discussion 3 01-16-2018 04:21 AM
1995 425 magnum 4x4 oversized piston alw3877 Polaris Magnum 1 01-01-2018 05:55 PM
Magnum 425 (1995) will idle fine but won't throttle up....pops alot freebs111 ATV Repair and Maintenance 0 12-15-2016 12:21 PM
