Need help with 850 overheating - Page 2 - Polaris ATV Forum
 1Likes
post #11 of 13 (permalink) Old 03-31-2019, 05:50 PM Thread Starter
BlackX's Avatar
Anyone???
ID:	117065   Click image for larger version
2013 850 Touring HO EPS, 6” Highlifter, 34” Intimidators, Rad Relo, Stealth Snorkel
2012 850 XP LE EPS 6” Highlifter, 32” Intimidators, Triangle Stealth Snorkels
SOLD–'17 Outlander XMR 1000, 6” Catvos, Turners, 32” Terms
SOLD–‘13 Ranger 900 XP EPS, 5" S3 lift, 29.5" Terminators
SOLD–'12 CMMDR X, 6" Catvos, Gorilla Axles, 32" Terms
SOLD–'06 Rhino 660, 6" Gorilla Lift w/ axles, 27" Mega Mayhems
SOLD–'05 Sportsman 700 Twin, 2" SuperATV Lift, 30" MudLites
Working overtime to pay for it all!
BlackX is offline
post #12 of 13 (permalink) Old 03-31-2019, 07:34 PM
@BlackX
Originally Posted by BlackX View Post
Hey Latebird. Thanks again for input. Are you a mechanic by trade or just have good exposure?
I guess I failed to see this post - I do not have great experience with the 850, so I just scan the posts and only answer when I think I might have a good suggestion.
I am a mechanic by trade - I have run an independent repair shop for over 40 years. I work on most makes and models, but I'm nearly 70 years old and I'm slowing down a bit. I'm not taking all jobs any more. I will not take the engine out of a Gold Wing, Harley or any other big bore street bike. I turn away all fuel injection problems, but I relish most electrical problems. My son is a general contractor. I fix his bike and he fixes my home and shop. I worked 25 years as a maintenance supervisor in a steel siding/roofing roll forming manufacturing plant. I have a degree in electronics, grew up on a farm and managed a Montgomery Ward store for 4 years, not in that order and that is not my complete resume.
indyred570 likes this.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #13 of 13 (permalink) Old 04-01-2019, 04:12 AM
Anyone???
Op, from your description, it sure sounds to me like either the fan breaker or relay or possibly an ECU issue. I saw where you said you replaced the breaker... You sure you got the right one? Sounds just like a RZR I worked on recently. It would cool/fan cycle perfectly while sitting or just cruising easy but when you got the machine under load for a few minutes the breaker would start overheating and couldn't keep up causing it to eventually overheat.
It sounds to me like you've covered all the mechanical/physical stuff. I'd first make sure the fan breaker and relay and the connections to them are good. If no joy there, I'd look into a ECU reflash. That could possibly correct the other codes you're getting too?
polman500 is offline
Over voltage Keith338 ATV Repair and Maintenance 28 12-20-2018 09:43 AM
Top end crankcase Masterbreaker101 ATV Repair and Maintenance 3 11-30-2018 11:59 AM
Shock interchange TDMax Polaris XP 7 07-13-2016 05:21 PM
Buddys 850 XP overheating CB73 Polaris Sportsman 6 05-15-2016 09:55 AM
