‘95 Magnum not running right - Polaris ATV Forum
post #1 of 6 (permalink) Old 12-03-2018, 05:21 AM Thread Starter
Willy's Avatar
Bought this ‘95 Magnum 425 4x4 last year primarily for ice fishing. Previous owner put a new carb in before I bought it and it ran good. Went to fire it up this weekend and it gave me a hell of time getting it started.
Finally got it started on full choke by backing the idle screw all the way out. But the second you give it gas or take the choke off it dies instantly. But it’ll all day long at full choke as long as you don’t touch the throttle.
Pulled the carb and it was spotless.
Pulled the fuel pump (original) and it wasn’t horrible, but I’m getting a new one to eliminate all possibilities. Also getting a new inline filter.
Anything else I should check while I’ve got it all torn apart?
1995 Polaris Magnum 425 4X4
Willy is offline
post #2 of 6 (permalink) Old 12-03-2018, 05:34 AM
If it will only run using the enrichener, the carb needs to be serviced or the gas may be stale - it's not how clean the float bowl is, it's how clean the metering circuits are
latebird is offline
post #3 of 6 (permalink) Old 12-03-2018, 05:37 AM Thread Starter
Willy's Avatar
So replacing the original fuel pump and the existing filter will only help my situation.
I'll dump the gas and put fresh of that in as well.
Willy is offline
post #4 of 6 (permalink) Old 12-03-2018, 07:44 AM
stave7119's Avatar
When you had the carb off did you spray carb cleaner through all the passages? Your symptoms indicate that enough fuel is getting into the float bowl but not through the jets into the engine. It can't hurt to change the pump and filter, but I think you need to clean out the carb also if you haven't already.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #5 of 6 (permalink) Old 12-10-2018, 07:11 AM Thread Starter
Willy's Avatar
Part #29 ended up being clogged solid with green gunk. Runs like a champ now!
https://cdn1.bikebandit-images.com/s...3237_242_4.gif
Willy is offline
post #6 of 6 (permalink) Old 12-10-2018, 08:45 AM
Part 29 is the pilot jet - the green gunk is usually algae which is a by-product of alcohol blended fuel
latebird is offline
Sportsman 600 Primary Help Needed TooSlo ATV Repair and Maintenance 8 07-23-2018 11:58 AM
95 xplorer transmission case Posdeer ATV General Discussion 3 01-16-2018 04:21 AM
