1991 trail boss 250 oil warning - Polaris ATV Forum
post #1 of 6 (permalink) Old 12-26-2018, 05:45 AM Thread Starter
copter14's Avatar
1991 trailboss 250 4x4 w918127
This bike had new top end rebuilt before i bought it bike starts and runs lots of smoke so i know it is getting oil but when bike is put into gear oil light on dash comes on?
2 stroke oil is more than half full and i dont see any sensor anywhere on bike.
Fan has been converted to switch on and off.
Any ideas on why oil warning comes on?
could a bad battery cause this, but battery starts quad no issues?
copter14 is offline
post #2 of 6 (permalink) Old 12-26-2018, 07:23 AM
Unless I'm mistaken, your machine doesn't have an oil warning light. It has what Polaris calls a "Pilot light lens asm." From left to right its Hot(red), Neutral(green), High Beam(blue), Reverse(yellow), 4x4(red).
You said it comes on when you put it in gear. If its the red light on the right then that's the 4x4 indicator.
Here's a picture:
https://www.ebay.com/itm/New-OEM-Pol...S!-1:rk:1:pf:0
polman500 is offline
post #3 of 6 (permalink) Old 12-26-2018, 09:06 AM Thread Starter
copter14's Avatar
unless someone has changed the dash part it defintely read oil but i will check again.oil message makes no sense anyways.
looks like this one is on quad so i agree it must be wrong.
https://www.ebay.com/itm/91-1991-POL...EYzk:rk:1:pf:0
copter14 is offline
post #4 of 6 (permalink) Old 12-26-2018, 11:51 AM
There is more than one wiring diagram for the 91 Trail Boss 4x4 - some indicate 5 dash lights, but all indicate only 4 active - t none of the wiring diagrams I looked indicated an oil light.
By the wiring diagrams, you have dash lights for neutral (green), high (blue), reverse (amber) and 4x4 (red) there was a 5th light that was not wired on your machine and it was a red light for temp on the liquid cooled models - the parts diagram does not indicate a sending unit for the oil tank - the fan was an option, if the fan was not wired correctly, it might cause the hot light in the dash to come on.
latebird is offline
post #5 of 6 (permalink) Old 12-26-2018, 12:27 PM Thread Starter
copter14's Avatar
fan is wired to toggle switch on and off ill try and see if it turns that light off
copter14 is offline
post #6 of 6 (permalink) Old 12-27-2018, 05:26 AM Thread Starter
copter14's Avatar
thats what i got took it apart got them all lighting up neutral works high beam works reverse works and far right works when in gear so i ordered the proper overlay for it that polman500 linked thank you both for the help. @latebird and @polman500
copter14 is offline
1997 trail boss 250 pre-mix oil mthreat ATV General Discussion 1 10-03-2018 12:15 PM
1995 425 Magnum zflowers2852 ATV Repair and Maintenance 5 09-24-2018 09:15 AM
Flywheel nut 3083905 latebird ATV Repair and Maintenance 0 08-14-2018 02:34 PM
Compatibility matt1932 Polaris Scrambler 1 07-11-2018 08:49 AM
wheel stud replacement dbweathe ATV Repair and Maintenance 3 01-24-2018 11:01 AM
