Life expectancy of non greasable ball joints??? - Polaris ATV Forum
 2Likes
post #1 of 15 (permalink) Old 04-11-2019, 01:29 PM Thread Starter
1948boat's Avatar
Location: Burr Oak in the summer and ride my motorcycle in FL durring the winter
Just got my new All Balls ball joints and realized they are compleatly sealed. In other words there is a solid plate/disc on the bottom end of the new joints not allowing any grease from the zerk that is in the strut housing for greasing the ball joint. I have read that some are drilling a hole in the plate/disc to allow grease to inter the joint. It is sad to pay for the joint and then have to modify it to get some decent life out of it. Or am I worring about nothing. We don't intentionally go mudding other what you may encounter on a trail and then I would rather drive arount it than go through it. So I'm wondering what experince you all have had??
1948boat is offline
post #2 of 15 (permalink) Old 04-11-2019, 03:09 PM
stave7119's Avatar
I have installed a bunch of the All Balls joints without an issue. Like you I don't go through the water/mud if I don't have to. Ball joints are a wear item and will need to be replaced at some point. I would expect thousands of miles though.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is online now
post #3 of 15 (permalink) Old 04-11-2019, 04:36 PM Thread Starter
1948boat's Avatar
So you install and don't grease them, just replace them when they fail? My 06, 800 sportsman is 13 years old with only 941 miles, I suspect the ball joints are the stock ones and are not as tight as I feel they should be. If I wasn't putting wheel bearings in I wouldn't change them out now.
1948boat is offline
post #4 of 15 (permalink) Old 04-11-2019, 05:44 PM
stave7119's Avatar
Yes, but I haven't had to replace any of them yet. My son in law's Trail Boss got a set, and both of my 325 machines. I think I used them on my 600 too.
post #5 of 15 (permalink) Old 04-11-2019, 05:53 PM
ONLY the older models have greaseable ball joints. Its pretty hard to even find them nowdays unless you buy OEM's and they cost about $50 each. One redeeming thing about the "greaseless" ones is that they are very easy to remove by just taking the retaining plate off and pumping grease in the fitting to push them out.
BUT NOTE*** YOU NEED TO PRESS IN ON THE GREASE ZERK BALL WHEN PRESSING GREASELESS JOINTS IN TO LET THE AIR PURGE OUT FROM UNDER THE JOINT. IF YOU DON'T THE TRAPPED AIR CAN MAKE THEM NEARLY IMPOSSILBE TO SEAT.
polman500 is offline
post #6 of 15 (permalink) Old 04-11-2019, 06:03 PM Thread Starter
1948boat's Avatar
Is the zerk pressed in or screwed in? If screwed in one can just unscrew them to relieve air pressure correct?
1948boat is offline
post #7 of 15 (permalink) Old 04-11-2019, 06:07 PM
I'm not absolutely sure but I think they're pressed in.
post #8 of 15 (permalink) Old 09-16-2019, 04:51 AM
Desertdave's Avatar
What would you guys recommend for ball joints, All Balls or Big Boss ball joints? They look very similar to me, anybody have experience with either?
2016 Sportsman Touring 570 EPS
2002 Trail Boss 325
Desertdave is offline
post #9 of 15 (permalink) Old 09-16-2019, 05:30 AM
bp405's Avatar
I used aftertmarket ball-joints and tie-rod ends now I'm back to OEM. OEM is better from what I gather. Here's a pic of the AM ball-joints I just removed. I would gather these have 700-800 miles on them.
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
2020 Outlander® 1000R XXC
bp405 is online now
post #10 of 15 (permalink) Old 09-16-2019, 05:33 AM
stave7119's Avatar
I have used All Balls and had good luck with them
Ball Joints Kennorthstar Polaris Highlifter 11 02-26-2019 11:14 AM
lower ball joints moving quadrider1957 ATV General Discussion 1 06-21-2016 01:06 PM
lower ball joints moving quadrider1957 ATV Brakes & Suspension 1 06-21-2016 12:36 PM
Ball Joints finally went out. FredBear Polaris XP 14 04-04-2016 07:00 AM
lower ball joints 2013 sportsman 850 quadrider1957 ATV General Discussion 1 02-15-2016 06:36 PM
