Magnum 325 idling but bogging down when gas - Polaris ATV Forum
 1Likes
  • 1 Post By stave7119
post #1 of 3 (permalink) Old 04-13-2019, 05:10 PM Thread Starter
Sdavis's Avatar
I have replaced carb new spark plug.very hard to start,when it starts it will set and idle then you can ride a few minutes then it backfires and dies then restart and you canít give it gas or it will die Iím at my wits end any help would be great
Sdavis is offline
post #2 of 3 (permalink) Old 04-13-2019, 06:23 PM
stave7119's Avatar
hat was the issue that caused all the changes? Is your carb one of the cheap Chinese knock offs? If it is then look there first. Too often on the forum we see that "fit" your machine doesn't always mean it will work properly with your machine. It might not be jetted right for your location or the needle jet could be the wrong style.
I find that rebuilding the OEM carb gives me much better results.
SunShine01 likes this.
Hers: 2007 Sportsman 500 EFI, Polaris Winch, 26" Bear Claw HTRs on Moose 427x Wheels. QSC Clutch Kit, Hand Warmers
2001 Magnum 325 Warn winch and Moose 60" plow
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #3 of 3 (permalink) Old 04-14-2019, 06:02 AM
Hard starting could be a compression issue - check the valve adjustment before going buying more parts - the spark plug was a good investment, but the carb was probably not and the carb might be all your problem now.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
Fitting another model muffler to '00-'02 Magnum? RacerP Polaris Magnum 5 01-11-2017 05:06 AM
