Need help with 2002 Polaris 700 twin with no electrical power - Polaris ATV Forum
post #1 of 5 (permalink) Old 04-18-2019, 05:13 PM Thread Starter
WyattBarnett's Avatar
I was riding it and all of a sudden it just died the fans where still on and running but no lights or the gage cluster wouldn’t work. So I’m wondering if anybody has had these types of issues and would throw out so advice for what to check there’s no obvious broken wires or separated parts. My local dealer said it’d be $70/hr for them to look at it so any help would be greatly appreciated. Thank you
WyattBarnett is offline
post #2 of 5 (permalink) Old 04-19-2019, 02:43 AM
bp405's Avatar
Fuses???
2011 Sportsman® 800 EFI
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
2018 Sportsman® 570-T
2019 Aluma® A8818
bp405 is offline
post #3 of 5 (permalink) Old 04-19-2019, 04:19 AM
Grab a meter and start checking voltage at the battery and work out from there... Ignition switch, kill switch, breakers, etc. to determine where you're losing it.
polman500 is online now
post #4 of 5 (permalink) Old 04-19-2019, 09:24 AM
You are in luck! Your ignition does not require DC power to function - it is self excited. The spark is killed by connecting the CDI module black wire to ground.
If you unplug the black wire and the engine runs, the problem is in the kill circuit. If there is no spark with the black wire disconnected, the problem is in the ignition system.
Unplug the black wire from the CDI unit and let us know the result.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is offline
post #5 of 5 (permalink) Old 04-19-2019, 01:58 PM
Oh yeah, didn't think about unhooking the ground wire. That would actually be the FIRST thing to try.
Any Polaris deep parts connections? TDMax Polaris Sportsman XP 1000 10 02-09-2019 09:13 AM
Polaris Ground Cable Lenght Hondov65 ATV General Discussion 3 02-06-2019 08:46 AM
2002 700 Twin Lund1700 ATV Repair and Maintenance 0 08-13-2017 06:02 AM
2002 700 twin hard starting when cold 4Footer Polaris Sportsman 6 02-18-2016 04:39 PM
2002 sportsman 500ho, no electrical power. Xforce41 ATV Repair and Maintenance 5 01-29-2016 05:49 AM
