Oil dipstick broken off inside motor - Polaris ATV Forum
 4Likes
post #1 of 16 (permalink) Old 04-29-2019, 01:41 PM Thread Starter
Highlifter8502019's Avatar
Today i was checking my oil on my 19 highlifter 850 and i pulled out my dipstick it was broken about 3 inches from the bottom and the other piece is sitting in the bottom somewhere and I’m not sure what to do i have started it up and ran it twice after i noticed it only to put in on the ramps and back in the garage need some advice on what i can do to fix it
Highlifter8502019 is offline
post #2 of 16 (permalink) Old 04-29-2019, 05:00 PM
Get a new dip stick. Next time you drain/change it see if you can fish the other piece of plastic out. Otherwise just act like you don't know its there.
polman500 is offline
post #3 of 16 (permalink) Old 04-29-2019, 05:15 PM
FPD218's Avatar
How is this continuing to keep happening? This is at least the 5th post on broken oil dipsticks on 850's in the last month or so? I just purchased a new 2019 850SP and don't want this to happen. Why are they breaking?
JUNE 2017 & SEPTEMBER 2018 POLARIS FORUM ATV OF THE MONTH WINNER
2019 Sportsman 850 SP Premium
Removed all Warning Decals
3500# Polaris Winch W/Synthetic Rope
Winch Stopper Cable Line Saver
ATV-GURU.COM Front and Rear Bumpers
2" Receiver in Front Bumper
Kenda K587 HTR Bear Claws 26X9X14 & 26X11X14
Ultimate Series Windshield Fairing, Mid Height Windshield
New Style Polaris Lock & Ride Rear Storage Box
Garmin GPS176
Polaris Rear View Mirrors
4" Front Rack Extender
Center Brake/Tail Light LED
Rear LED work lights/strobes
Built on March 27 2019
Purchased New April 13 2019 0.1 Hr .2 Mi
Power Sports Abrams, Wi
SOLD
2006 Sportsman 800 EFI Twin
Purchased new to me on Aug 08 2016 97Hr's 811Mi
Sold Apr 07 2019 231 Hr 3126 Mi
https://www.youtube.com/watch?time_c...&v=k6Nlb_qRoeg
"I am the majority!"
*WEAR A HELMET, I'M LIVING PROOF THEY WORK!
FPD218 is offline
post #4 of 16 (permalink) Old 04-29-2019, 05:23 PM Thread Starter
I want to forget about but im worried about it getting sucked into a cylinder or something so i want it, out you don’t think it will cause a problem ?
post #5 of 16 (permalink) Old 04-29-2019, 06:57 PM
jo191145's Avatar
I want to forget about but im worried about it getting sucked into a cylinder or something so i want it, out you donít think it will cause a problem ?
I would certainly want it out. You can push a ping pong ball through steel with enough velocity.
jo191145 is offline
post #6 of 16 (permalink) Old 04-29-2019, 07:01 PM
Gulf550's Avatar
If you try and put the dip stick in place in a hurry, I can see it breaking. Even when I'm trying to take my time, it doesn't seem like it's fitting properly, so I take it back out and try to make sure I put it in straight.
When you change your oil next, you can try and fish it out. I don't think you will be able too. There is a oil catch plate that is bolted to the lower case half. It sits below the crank shaft. The dip stick will be under the plate and you don't have to worry about it getting picked up my the crank. There is a small possibility I guess, the oil pump can pick it up. But it would be hard. The 2011 850 motor I rebuilt had just about the entire dip stick stuck in the bottom of the engine case. Never caused a problem. The only way I think you would be successful in getting the piece out is pulling the engine and separating the case halves. If it happened to me, I would just forget about it and when something does happen. Blame the wife. :-) J/k.
Gulf550 is offline
post #7 of 16 (permalink) Old 04-30-2019, 04:27 AM
"Blame the wife. :-) J/k. "
I've seen a couple guys talk about using a little grab tool to fish them out right after it breaking and before it gets moved around but its hit or miss. I think if you aren't careful to insert the stick straight inline with the hole past the balance shaft it'll snap it off when you tighten it down.
post #8 of 16 (permalink) Old 04-30-2019, 05:28 AM
TheStatelineATV's Avatar
yeap. "we' had a luck and we removed it with tool like this :
https://www.grainger.com/product/6TF...g!502447222717!
took few minutes to have it fixed.
good luck
TheStatelineATV is offline
post #9 of 16 (permalink) Old 04-30-2019, 06:18 AM
MNDS's Avatar
I have wondered the same thing, how are these dipsticks breaking? I have noticed if you donít get the dipstick in straight in the hole past the balance shaft it wonít go in properly or almost impossible to tighten it.
I wonder if the broken dipsticks are just bad parts or are guys spraying brake cleaner on them.
2017 Sportsman XP 1000
RJWC Exhaust
RVS Performance ECU flash
2004 Sportsman 600 Twin
MNDS is offline
post #10 of 16 (permalink) Old 04-30-2019, 06:24 AM Thread Starter
Problem with that is i can’t see it and i have no idea where it is
1987 Trailboss es/r 250CC starter shot Rufusjr Polaris Trail Boss 2 04-28-2019 01:53 PM
Oil injector pump rebuild kit 1991 Trail Boss SaturdayShoppe ATV Repair and Maintenance 2 03-30-2019 09:47 AM
Another chose to replace Polaris oil PoPo3 ATV Oil, Lubrication & Filter 1 10-31-2018 07:23 AM
2014 Sportsman 570 Oil-Filters rotor Polaris Sportsman 570 23 06-01-2017 05:16 PM
