Need help-polaris 850 engine won't spin once crankcase half torqued down - Polaris ATV Forum
post #1 of 8 (permalink) Old 04-29-2019, 03:01 PM Thread Starter
Actmobmar's Avatar
So I'm in the middle of rebuilding my buddies 2017 850 sportsman engine. It ingested water, he thought he got all of out but didn't, engine didn't sound right, so he shut it off and pulled it out. I took the engine apart, had some scuffing on the pistons, and the main bearings looked bad, and crank was scored. So I got a new crank, and bearings. Reassembled the engine, spins freely. As soon as you torque down the bottom crankcase cover it doesn't spin, and feels locked up. It didn't spin a main bearing or anything like that when he had the issues. So what am I missing?? Thanks!!
Actmobmar is offline
post #2 of 8 (permalink) Old 04-29-2019, 07:06 PM
Gulf550's Avatar
So, I'm not sure if this can cause the problem, what color crank bearings did you put in? I'm not entirely sure how to judge which bearings to order? I'm guessing it's based off of the crank diameter? Is it possible the color bearings you ordered are to small? I'm just throwing out ideas. Not sure if it can cause the problem.
Gulf550 is offline
post #3 of 8 (permalink) Old 04-30-2019, 03:05 AM Thread Starter
Actmobmar's Avatar
Bearings Came with the crank for the mains.
post #4 of 8 (permalink) Old 04-30-2019, 08:31 AM
The bearing shells are different for the center than the ends - maybe you got them mixed up?
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is online now
post #5 of 8 (permalink) Old 04-30-2019, 10:35 AM Thread Starter
Actmobmar's Avatar
Center bearings have full grooves in them, outers don't, and the bearing tangs are in different spots so they don't swap around. As soon as I snug the case cover down it binds. I even disassembled the whole short block again, and am just testing it with just the crank
post #6 of 8 (permalink) Old 04-30-2019, 01:43 PM
MNDS's Avatar
Makes you wonder if the case main bearing bores are not concentric with each other. Have you tried just 2 bearings at a time, maybe remove the center main and see if rotates or changes at all, or the center main and one outer. I'm sure you looked at all the obvious things , dirt, burrs ect.
2017 Sportsman XP 1000
RJWC Exhaust
RVS Performance ECU flash
2004 Sportsman 600 Twin
MNDS is offline
post #7 of 8 (permalink) Old 04-30-2019, 06:39 PM
Plastigage the bearings on various axis
2006 Trailboss 330
2002 Sportsman 90
2004 CRF250X
1989 Honda VT1100C
post #8 of 8 (permalink) Old 05-01-2019, 04:09 AM Thread Starter
Actmobmar's Avatar
I put the bearings in last night again, scotchbrited the bearing bores before install, torqued down the case halves and used a telescoping guage and measured the inside bore with the bearings installed, it comes out that the bore size is .001 under on the stator side bearing??? I don't get it, this engine never spun a bearing. One thing I do notice, with the bearing shells installed they stick up slightly from the case halves, when fully pushed down?
99 POLARIS SPORT 400 ENGINE help blackice2242 ATV Parts Wanted 0 09-13-2017 05:05 PM
Polaris Sportsman 850 and 1000 ATVs Recalled VS_Goose Polaris ATV News 4 03-26-2017 07:11 AM
Polaris 850 sportsman engine wanted Ndw1976 ATV General Discussion 0 03-03-2017 09:51 AM
2015 polaris sportsman etx engine swap Langlais23 ATV Performance Modifications 3 12-23-2015 01:10 PM
Welcome to the new Polaris ATV Forum! dascrow Polaris ATV News 2 09-20-2010 01:39 PM
