how does this work? - Page 2 - Polaris ATV Forum
 5Likes
post #11 of 34 (permalink) Old 05-02-2019, 10:54 AM
Sounds like its idling ok.
Pull the belt off and check the one-way clutch bearing.
Poveiro likes this.
polman500 is offline
post #12 of 34 (permalink) Old 05-02-2019, 11:16 AM
rutcutter's Avatar
Well I learned something reading this thread. I had never seen one of my quads running with the clutch cover off. I never knew the secondary clutch spins at idle. I always figured they were like snowmobiles and stopped at idle.
My name is Mike
These are a couple of my many rides:
2018 Sportsman 1000Xp
Havasu red pearl
3500# Polaris winch with wireless remote
2500# Badland rear mounted winch with wireless remote
Interco Sniper 920 tires
Elka stage 3 shocks
Ricochet 8 piece belly armor with UHMW composite slides
Bad boy airhorn
Tusk street legal kit
Bar end rearview mirrors
LED headlights
LED daylight driving lights
Koplin lock N ride tool/gun holders
Tusk heated grips and thumb warmer
Polaris rear third brake light
Polaris ultimate hand guards and mounts
12" quad row LED light bar
Rear LED flood lights
Bluetooth Firehouse sound system
Gen 3 Spot locator
Garmin 750T GPS/GMRS radio
Go Pro with mounts all over
2004.5 Sportsman 500 50th Anniversary edition
Sadly collecting dust in the shop, now that I got the 1000XP
rutcutter is offline
post #13 of 34 (permalink) Old 05-02-2019, 11:38 AM
It will stop when put in gear. Sometimes, if everything is exactly perfect, they will not turn in neutral either but that's pretty rare. Even when turning at idle, unless there is too much drag from the belt, you can still stop the secondary easily with your foot. I know nothing about sleds but aren't they always in gear?
post #14 of 34 (permalink) Old 05-02-2019, 01:26 PM
MNDS's Avatar
Originally Posted by Poveiro View Post
Any one else with other opnions about what can be the problem?
So I can investigate the possibilities.
Thanks in advance.
You might have the wrong belt, 321113 is for machines built before 8-7-2006. Looking at your driven clutch I think its the newer clutch, belt part number 3211091 for the driven clutch in your video.
Depending on who's website you look at...but Dayco claims the 3211091 is .125 longer than the 3211113
2017 Sportsman XP 1000
RJWC Exhaust
RVS Performance ECU flash
2004 Sportsman 600 Twin
MNDS is offline
post #15 of 34 (permalink) Old 05-02-2019, 02:17 PM
Thanks in advance.
Yep, good eye MNDS. The belt that's on it, if its a 3211113, does NOT appear to match the clutches.
A 2007 Sportsman 500 actually uses one of THREE different belts according to build date and/or clutch types. Not sure if that's the sole cause shifting problems but it may be a contributing factor.
3211077
3211113
3211091
post #16 of 34 (permalink) Old 05-02-2019, 02:39 PM Thread Starter
Poveiro's Avatar
/QUOTE]Yep, good eye MNDS. The belt that's on it, if its a 3211113, does NOT appear to match the clutches.
3211077
3211113
3211091[/QUOTE]
10/4/2006 thats the date on the frame.
Poveiro is offline
post #17 of 34 (permalink) Old 05-02-2019, 03:11 PM Thread Starter
Poveiro's Avatar
here is the date.
Poveiro is offline
post #18 of 34 (permalink) Old 05-02-2019, 03:13 PM
MNDS's Avatar
3211077
3211113
3211091
10/4/2006 thats the date on the frame.[/QUOTE]
Then you should be using the 3211091 belt. The 3211077 is for machines without EBS. Do you still have the old belt? If you do you can do a table roll out measurement on both belts and compare.
Put the belt on a bench or table,put a line on the belt and table with a sharpie, roll the belt one revolution, mark the table, measure the length, repeat the same on the other belt.
RJWC Exhaust
MNDS is offline
post #19 of 34 (permalink) Old 05-02-2019, 03:20 PM Thread Starter
Poveiro's Avatar
No, unfortunately don't have the old belt.
This 4 wheeler is from a family member.
Going to call him and see.
Will let know in here as soon as I can.
Thanks.
Poveiro is offline
post #20 of 34 (permalink) Old 05-02-2019, 04:34 PM Thread Starter
Poveiro's Avatar
I have been told that the old belt was taken to the store to buy the same one.
So if the belt number is the wroung one was already changed by the previous owner.
When @latebird said that maybe was the wroung belt I checked on line and give me the 113 belt.
Poveiro is offline
Led tail lights that work fast.5 ATV Visual & Body Modifications 27 10-18-2018 07:03 AM
Will 2009 sportsman 850xp parts work on 2012xp? Carey.hutch ATV General Discussion 0 05-11-2018 05:38 AM
6x6 lawn work Kingkat4 ATV General Discussion 3 03-07-2017 10:22 AM
What else makes the Hall Sensor work? Supraman23 ATV Repair and Maintenance 0 01-13-2017 07:22 AM
cigarette port led work light mckishen Polaris Sportsman 3 12-17-2015 01:55 PM
