how does this work? - Polaris ATV Forum
 5Likes
post #1 of 34 (permalink) Old 04-29-2019, 06:07 PM Thread Starter
Poveiro's Avatar
how does this work?
Hi, everyone, new in here.
First time doing maintenance and repairs on a Quad but not on Motorcycles or autos.
This Quad from a family member as a problem with shifting, its hard to go from park to drive and so on.
Is this a normal idle for this kind of clutch?
Should one of this fly wheels speen free not to create pressure on the gears making it hard to engage into gear when in idle?
Poveiro is offline
post #2 of 34 (permalink) Old 04-30-2019, 06:20 AM
Jason537's Avatar
Put the primary bolt back in first, your belt might be misaligned.
Hers 2014 570 sportsman,
2" AtvE lift
His 2013 850xp LE, currently under REPAIR for spun timing gear
28" Zillas
QSC clutch kit
1.5" lift
LTE slip-on,
Jason537 is offline
post #3 of 34 (permalink) Old 04-30-2019, 06:36 AM Thread Starter
Poveiro's Avatar
I removed the bolt to remove the clutch. She as not been removed at this time. I just filmed so I could ask in here, basically I remembered to film after had removed the bolt.
If I put the bolt back will be no change as nothing was touched at the moment.
But I can put it back and film again if it helps diagnose the problem.
Poveiro is offline
post #4 of 34 (permalink) Old 04-30-2019, 07:04 AM
The belt looks tight - either the primary clutch is not opening fully, perhaps it's an EBS bearing that has locked up or perhaps even the wrong belt. It appears the belt is at the proper position on the secondary clutch indicating that the clutch has closed fully, but the possibility exists that the secondary clutch was worked on and is not operating as designed.
2006 Trailboss 330
2002 Sportsman 90
2005 TRX400EX (FOR SALE)
2004 CRF250X
1979 Honda CBX (6 cylinder)
1981 Kawasaki KZ305-A
1989 Honda VT1100C
latebird is online now
post #5 of 34 (permalink) Old 04-30-2019, 07:19 AM Thread Starter
Poveiro's Avatar
I will have a check at the belt number later and do a full pic of all the movement the clutch does.
Poveiro is offline
post #6 of 34 (permalink) Old 04-30-2019, 10:20 AM
I couldn't get the video to play but... HOLY COW!! Don't be running that thing with the drive clutch bolt out. If it were to fly off it would likely kill anyone nearby and probably destroy the clutch and anything else it hit!
If it worked ok before it probably just needs both clutches rebuilt.
You might try turning the idle down a little if its running pretty fast but I'm doubting that will fix it.
polman500 is offline
post #7 of 34 (permalink) Old 04-30-2019, 11:27 AM Thread Starter
Poveiro's Avatar
I put the bolt back. You are right, shouldn't have started without the bolt.
Poveiro is offline
post #8 of 34 (permalink) Old 04-30-2019, 11:57 AM Thread Starter
Poveiro's Avatar
So I checked the belt and its the right one.
Contrary to my thoughts its a 2007, I had seen on the frame 2006 but at the Polaris site by serial number it says 2007 model.
The belt is 3211113.
All the searches I have done are pointing to the need of a shim, but...
Name:	Belt 3211113.jpg
Poveiro is offline
post #9 of 34 (permalink) Old 04-30-2019, 12:05 PM Thread Starter
Poveiro's Avatar
Some how clicking on the play arrow it gives an error, but if you clic on the link above the image, it works.
Don't no why does that.
Poveiro is offline
post #10 of 34 (permalink) Old 05-02-2019, 10:34 AM Thread Starter
Poveiro's Avatar
Any one else with other opnions about what can be the problem?
So I can investigate the possibilities.
Thanks in advance.
Poveiro is offline
Led tail lights that work fast.5 ATV Visual & Body Modifications 27 10-18-2018 07:03 AM
Will 2009 sportsman 850xp parts work on 2012xp? Carey.hutch ATV General Discussion 0 05-11-2018 05:38 AM
6x6 lawn work Kingkat4 ATV General Discussion 3 03-07-2017 10:22 AM
What else makes the Hall Sensor work? Supraman23 ATV Repair and Maintenance 0 01-13-2017 07:22 AM
cigarette port led work light mckishen Polaris Sportsman 3 12-17-2015 01:55 PM
