Fuel issues - Polaris ATV Forum
 2Likes
  • 1 Post By stave7119
  • 1 Post By latebird
post #1 of 10 (permalink) Old 05-10-2019, 11:08 AM Thread Starter
OleMiss2019's Avatar
Fuel issues
Help!!!..I'm restoring (or trying to) a 1988 Polaris 250 Trail Boss..I had it running, a good idle ..I let it run for a bit and it speeded up by itself and stopped..It'll run while starting fluid is being sprayed..I assume it's not getting gas ..And I do still have the oil injection pump hooked up..And "NO" I'm not the best of mechanics but I enjoy tinkering with them..lol..Any suggestions. I'd appreciate it..Thanks in advance Pete
OleMiss2019 is offline
post #2 of 10 (permalink) Old 05-10-2019, 02:13 PM
stave7119's Avatar
Check the compression? Are you sure the injection pump is working? If all that is good then you need to start tracing the fuel flow to the carb. If you have fuel getting to the carb but not into the engine, then the carb has to come off for a good cleaning.
OleMiss2019 likes this.
2018 Kawasaki KLR650
SOLD 2004 Sportsman 600 Twin
stave7119 is offline
post #3 of 10 (permalink) Old 05-11-2019, 05:44 AM
Usually when the engine speed up just before it dies, it's an indication of the carb running out of fuel - it leans out, speeds up then dies - check the fuel delivery to the carb - make sure you are using fresh fuel and non-ethanol is best
latebird is offline
post #4 of 10 (permalink) Old 05-16-2019, 09:42 PM Thread Starter
Thanks.i took the carb back off gave it a good cleaning..It'll start but will run wide open.. Backing out the "idle screw" doesn't help...Thanks again for the help...Pete
post #5 of 10 (permalink) Old 05-17-2019, 05:35 AM
The Slide is not closing completely - check the throttle cable to assure it is seated at all junction points - make sure the slide needle is not jammed in the needle jet - make sure the slide groove is engaged with the guide pin in the side of the slide bore - make sure the cable is adjusted correctly - is the idle screw you removed the speed screw or the mixture screw - make sure the carb is fully seated in the holder - check the carb holder for cracks - that's about all I can think of as potential problems
latebird is offline
post #6 of 10 (permalink) Old 05-17-2019, 10:14 AM Thread Starter
Thanks for the help..I'll go over all of the suggestions you made..Just curious? If I decide just to purchase a after market carb..The only thing that I need to know is that it is a 36mm?..Right?..My old carb is a Mikuni VM series 36mm round slide..I'm hope there's others that are interchangeable..Thanks...Pete
post #7 of 10 (permalink) Old 05-17-2019, 10:33 AM
If I were guessing I'd say the slide is turned the wrong way.
polman500 is offline
post #8 of 10 (permalink) Old 05-17-2019, 02:04 PM
stave7119's Avatar
I would not replace the carb unless you are gonna part with the big bucks for a new Mikuni piece. Check the posts on the forum. Way too many where they got a cheap Chinese knock off carb and had problems making their machine run right. Unless it is cracked or broken you are much better off to use the original piece.
post #9 of 10 (permalink) Old 05-18-2019, 09:14 PM Thread Starter
Slide turned the wrong way?..Could be it...I'll to tinker with it again..I thought if the slide fell in easily that it would automatically be correct...Thanks for the advice..
post #10 of 10 (permalink) Old 05-18-2019, 09:27 PM Thread Starter
You're probably right about the carbs from China..I'll probably keep my Mikuni and keep working on it..My problem is, I've always been frugal (some say cheap) lol.. Appreciate the advice though...
Common Carb Issues pfunk76 ATV Repair and Maintenance 117 03-30-2019 08:09 AM
Fuel issues egwiazda ATV Repair and Maintenance 10 10-19-2018 11:03 AM
Fuel Issues? TheFire238 Around The Garage 2 05-04-2018 11:11 AM
1998 Magnum 425 fuel issues? bldmtnrider Polaris Magnum 6 08-09-2017 07:40 AM
Sportsman 500 EFI spark and fuel issues Jedeka Polaris Sportsman 0 11-24-2016 04:53 AM
